Checking the TSI fuel injectors in their installed state?
hVgti
2010 Volkswagen Golf
Post03-02-2019, 16:26    Subject: Checking the TSI fuel injectors in their installed state? Quote
Hello everyone,
Can I check the fuel injection valves using VCDS on a TSI?
Are it sufficient to read the lambda values and misfires, or is there a better and more accurate method?
Greetings
Hannes
Golf 6 GTI - DSG - MKB: CCZB - MJ: 2011
Post06-02-2019, 21:18    Subject: Re: Checking TSI Injector Valves in Installed Condition? Quote
hVgti wrote:
Hello everyone,
Greetings
Hannes
Expand, there are testing and cleaning devices for this.
VCDS doesn't have a camera in the diagnostic port, so it can't see if it's dripping, sputtering, or anything else...
Best regards, Rainer
No new posts Golf 1J: Gear Shift Problems in Cold Weather Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Sealing the MSW (Motor-Schwingung-Welle) of a VP37 engine... Diesel Engine Technology
No new posts Inspect AHU Diesel Engine Technology
No new posts ZMSwing Check: Improve Your Golf Swing Diesel Engine Technology
No new posts Check Catalytic Converter: Symptoms & How To Diesel Engine Technology
