Airbag Control Unit Replacement: Incorrect Index?
Frank1986
Post09-02-2019, 16:43    Subject: Airbag Control Unit Replacement: Incorrect Index? Quote
Hello everyone, in a 1999 Caddy, the airbag control unit was replaced because the error memory indicated a defective control unit.
A control unit with index number AE was installed.
Now, one has been acquired with the index BL.
The control unit has a different coding, but unfortunately, I don't have a login code, and VCDS doesn't offer any suggestions either. The error code 00589 - Igniter 1 for passenger-side airbag (N131) doesn't appear with the old control unit. Can anyone tell me if it will work even with the different index if I recode it?
Attached is a vehicle scan, as well as screenshots of the old and new control units.
Thank you. Best regards, Frank.
 File size:  134.72 KB
 Viewed:  1373 times
 File size:  94.69 KB
 Viewed:  1188 times
Log-Log.txt
 File name:  Log-Log.txt
 File size:  2.16 KB
 Downloaded:  417 times
Translated on 23-09-2026, 10:36.
Post09-02-2019, 17:48    Subject: Airbag Control Unit Replacement: Incorrect Index? Quote
Please obtain the correct airbag control unit.
Translated on 23-09-2026, 10:37.
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Airbag Error 65535: A3 8L Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replace Airbag Control Unit: Guide & How-To On-Board Diagnostics (OBD)
No new posts Airbag Control Unit VW Golf 3 On-Board Diagnostics (OBD)
No new posts A3 TDI: Airbag Error 65535 - Troubleshooting On-Board Diagnostics (OBD)
No new posts SRS Airbag Control Unit E220D - W210 On-Board Diagnostics (OBD)
