Audi A6 4G Engine: How to Disable
KANE326
Post15-02-2019, 23:30    Subject: Audi A6 4G Engine: How to Disable Quote
Hello everyone,
My A6 has a really annoying coding issue. When I start the engine, close the door, drive a short distance (e.g., out of the garage), put the automatic gear selector in "P", and open the door, the engine turns off, and the ignition also shuts off!
While the documentation explains how to code it, it hasn't been helpful. Does anyone have any other suggestions?
Greetings.
Translated on 10-10-2026, 22:59.
bloesch
dieselschrauber likes this.
Post16-02-2019, 2:42    Subject: Audi A6 4G Engine: How to Disable Quote
You can also get this information from your car dealership using the SVM code.
Let it be disabled. This will also ensure that it remains disabled in future updates.
I'll have to check next week... it was a bit tricky to find, as I *think* it wasn't listed under the usual TPIs.
Translated on 10-10-2026, 23:00.
KANE326
Post17-02-2019, 14:30    Subject: Audi A6 4G Engine: How to Disable Quote
Do you mean this one? TPI 2033200.
bloesch
Post18-02-2019, 3:28    Subject: Audi A6 4G Engine: How to Disable Quote
Yes, that's probably it.
Translated on 10-10-2026, 23:01.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
No new posts Oil in Coolant: Audi 1Z Engine Problems Diesel Engine Technology
No new posts VW AFN Engine in Audi 80 TDI Diesel Engine Technology
No new posts Audi engine control unit (ECU) AAT - engine On-Board Diagnostics (OBD)
