STG08 Climate - Function limitation due to MSG
Post23-02-2019, 18:09    Subject: STG08 Climate - Function limitation due to MSG Quote
Hi there,
Can you explain this error message?
The vehicle is a Volkswagen Golf 7.
in the car scan (Appendix 2):
08 - Climate Control/Heating Unit - Status: Error 0010.
then
1048835 - Function limitation due to engine control unit.
P1719 00 [008] - -
[MSG-induced PTC reduction]
The error occasionally reappears.
Is the engine control unit (ECU) functioning as it should, but is the air conditioning control unit failing to do its job?
Log-WVWZZZAUZJWxxxxxxClimatronic.txt
 File name:  Log-WVWZZZAUZJWxxxxxxClimatronic.txt
 File size:  1.76 KB
 Downloaded:  772 times
Log-WVWZZZAUZJWxxxxxx-18165km.txt
 File name:  Log-WVWZZZAUZJWxxxxxx-18165km.txt
 File size:  12.79 KB
 Downloaded:  907 times
Translated on 10-07-2026, 10:22.
Post23-02-2019, 18:16    Subject: Re: STG08 Climate Control - Function Impairment due to MSG Quote
Yes, No!
The MSG wants to reduce the load and tells the air conditioner to turn off the PTC heater, which it does. Otherwise, you would certainly have found more error messages.
For me, this isn't a real error, but just a message indicating "I had to turn something off...".
The "error" (or rather, the phenomenon) can be caused, for example, by a weak battery.
Translated on 10-07-2026, 10:24.
Post23-02-2019, 18:23    Subject: STG08 Climate - Function limitation due to MSG Quote
So ähnlich habe ich mir das gedacht. So, should I ignore it?
The battery shouldn't be weak. The car is only a year old and has 18,000 km on the odometer. And this issue isn't new.
Translated on 10-07-2026, 10:26.
Post23-02-2019, 18:55    Subject: STG08 Climate - Function limitation due to MSG Quote
I would continue to monitor it and, before the warranty expires, check if there are any updates available for the relevant control units.
It might be a good idea to occasionally check the onboard voltage as well, just to make sure the battery isn't a defective unit.
No new posts TIP: DQ400 - P0867 Function limitation due to pressure drop Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Climate leakage due to improper maintenance? Urgent!! Transmission, Chassis, Body & Interior
No new posts Climate Change: Where is the Vaporizer? Transmission, Chassis, Body & Interior
No new posts Climate-Friendly ASZ: Agile Solutions! Diesel Engine Technology
No new posts Climate Control A4 Malfunction? Transmission, Chassis, Body & Interior
