P1351 error on a MITSUBISHI OUTLANDER II
kickpanther
Post04-09-2018, 22:30    Subject: P1351 error on a MITSUBISHI OUTLANDER II Quote
MITSUBISHI OUTLANDER II (CW_W), 2179 cm3, 156 hp, 115 kW, Production Year: 08/07 to 11/12, Type Approval Number: 7107-ACH.
Hello, I have read the following data from this vehicle:
Can anyone give me a tip?
Thank you for your help.
I already replaced the glow plugs today, cleared the error code, and the error is still gone, but it still shows up on the vehicle's display. Why is that?
Or better yet, how do I get rid of it???
KOBD2Check V1.80 Scan, 20180829-192301
http://shop.dieselschrauber.org/en
Reading vehicle information...
Diagnostic connection: 500,000 bits/second, 11 bits.
Internetverbindung für Steuergerätecheck (Software, CVN) notwendig.
--Does this mean that you need an internet connection to get more information?--
FIN: JMBXMCW7WCF005843
Calibration ID: 9666733799
Control unit:
Reading error codes...
Upcoming issues:
- P1351: Email: [email protected]
Stored errors:
https://community.dieselschrauber.org/en/search.php?source=KOBD2Check&search_keywords=P1351
Translated on 08-07-2026, 22:55.
Post05-09-2018, 18:28    Subject: P1351 error on a MITSUBISHI OUTLANDER II Quote
Powertrain Problem MFG - Manufacturer-specific, ignition system failure or misfire(s)
Is there absolutely nothing left in the error memory? Of the engine control unit?
There might be another error stored in the engine control unit that is not related to the OBD2 system.
Is the engine running smoothly?
Internet connection required for checking control units (software, CVN).
--does this mean that you need an internet connection here to get more information???--
This would only be useful for checking the CVN (Calibration Verification Number) or the software version of the engine control unit, and not for your specific application.
kickpanther
Post13-09-2018, 20:57    Subject: MITSUBISHI OUTLANDER II (CW_W), 2179 cm3, 156 hp, 115 kW, Year of Manufacture Quote
And first of all, sorry for the late reply.
Thank you very much for your reply.
There were no further errors stored in the engine control unit.
Regarding the vehicle's issue:
After that, I took it for a test drive, and then there was a loud bang, and it stopped working.
I am in the process of analyzing it. Once I have identified the problem and the error, I will continue writing here.
Best regards, Kay.
Post14-09-2018, 17:42    Subject: P1351 error on a MITSUBISHI OUTLANDER II Quote
After that, I took it for a test drive, and then there was a loud noise, and it stopped working.
Typical issues include a slipped or burst turbocharger boost hose, or a burst intercooler.
If no visible damage is apparent and no clamps are too loose/were too loose, observe the boost pressure regulation. icon_idea.gif
kickpanther
Post02-03-2019, 19:53    Subject: P1351 error on a MITSUBISHI OUTLANDER II Quote
I'd like to clarify what the mistake was.
The diesel particulate filter was full, which caused this error message.
Sorry for the late reply.
Best regards, Kay.
Post03-03-2019, 21:28    Subject: P1351 error on a MITSUBISHI OUTLANDER II Quote
Best regards, Kay
It shouldn't "explode" there, but thank you for the feedback regarding the error message! icon_smile.gif
No new posts Caddy Bj 07 BLS AGR Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with an ATM Diesel Engine Technology
No new posts Relay 109: Location for AFN vehicles Diesel Engine Technology
No new posts AJM -- Soot on a tandem pump hose Diesel Engine Technology
No new posts Pump replacement from an 81kW TDI engine Diesel Engine Technology
