BMW E87 116i N45B16A timing chain broken/jumped
chli1976
Post26-03-2019, 19:38    Subject: BMW E87 116i N45B16A timing chain broken/jumped Quote
Can someone tell me if it's normal for oil to spray out when drilling and turning the tool by hand?
"And whether the non-return valve is allowed to rotate within its housing when it's locked. I turn the non-return valve in or against the direction of rotation until it hits the stop (depending on the non-return valve), and then it should lock. But with mine, I can still turn the non-return valve without the chain being moved. Hopefully, you understand what I mean..."
BMW E87 116i N45B16A timing chain broken/jumped - 20190326_172406.mp4
 File size:  31.46 MB
 Viewed:  1245 times
VCDS
Translated on 18-07-2026, 10:28.
No new posts Audi A6 3.0 TDI Timing Chain Replacement Diesel Engine Technology
No new posts 1.8 TFSI BZB timing chain jumped Gasoline Engine Technology
No new posts Mercedes C200 Kompressor timing chain Gasoline Engine Technology
No new posts BLR 2.0 FSI Skoda Octavia: Replace timing chain of camshaft Gasoline Engine Technology
