1.2 TDI CFWA P0087 Delphie CR Injector
Marco_Gorski
Post15-06-2019, 2:44    Subject: 1.2 TDI CFWA P0087 Delphie CR Injector Quote
Hello fellow DIY enthusiasts,
I've been having problems with my Polo 1.2 TDI for a while. After the HDP (High-Pressure Diesel Pump) failed, I replaced everything and cleaned it all.
Now, 50,000 km later, the error code P0087 appears: fuel system rail/system pressure too low.
Das Fahrzeug fährt normal, einzige Auffälligkeit ist, dass er sehr laut nagelt wenn er kalt ist. (Nur beim ersten Anfahren. (Das Nageln verschwindet nach kurzer Zeit). Zusätzlich sind Leistungseinbußen bemerkbar (Anfahrschwäche und auf der Autobahn im 5. Gang certainly.
Sometimes, he just can't seem to break out of it.
I know it's a 1.2, but there's still more potential.
Can someone tell me if there's a faulty injector here, or what else I should check?
I checked the tank for wood shavings, and there are hardly any. A small amount of shavings is normal.
Marco.
1.2 TDI CFWA P0087 Delphie CR Injector - IMG_7337.MOV
 Video RĂźcklaufmenge bei 2500 rpm
 File size:  71.12 MB
 Viewed:  1514 times
1.2 TDI CFWA P0087 Delphie CR Injector - DAC8B231-75CA-4EEF-A435-D839C4F95E75.MP4
 Video RĂźcklaufmenge im Leerlauf
 File size:  25.18 MB
 Viewed:  1552 times
 VCDS AUSZUG
 File size:  6.58 MB
 Viewed:  1952 times
 VCDS AUSZUG
 File size:  6.22 MB
 Viewed:  1939 times
 VCDS AUSZUG
 File size:  7.33 MB
 Viewed:  1798 times
 RĂźcklaufmenge (Motor Betriebswarm) bei 2500 rpm
 File size:  1.81 MB
 Viewed:  1808 times
 RĂźcklaufmenge (Motor auf Betriebstemperatur) Leerlauf
 File size:  1.92 MB
 Viewed:  1687 times
Translated on 12-09-2026, 2:48.
No new posts Fuel pressure too low (P0087) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts CFWA - Diesel Particulate Filter Malfunction Diesel Engine Technology
No new posts Polo BM - 1.2 TDI - CFWA - Diagnostic PDF (Tips for me) Diesel Engine Technology
No new posts Sharan 2.0 P0087 - Low Rail Pressure Diesel Engine Technology
No new posts A6 3.0 Biturbo P0087 - Insufficient fuel rail pressure Diesel Engine Technology
