A4 B6 2,5 TDI 180 Ps BAU, Leistungsloch unter ca 2800 U/min | Posts 64+
Go to page: Previous  1, 2, 3, 4, 5
MrMcFly79
Post03-06-2019, 15:46    Subject: Quote
Can I buy them individually? Do you have a link?
I thought it wouldn't be possible because they are vulcanized.
dieselschrauber likes this.
Post04-06-2019, 10:18    Subject: Quote
I don't have a link; I bought them in a small lot. I'll check if there's a part number on the packaging.
dleds
Karma: +14 / -1   Thank you, like it!
Post04-06-2019, 11:34    Subject: Quote
Okay, here's an idea from a different angle.
If the engine pulls "almost normally" or normally in the higher gears, I would initially rule out anything that is cylinder-specific. The compression, injectors, and camshaft have no idea that the engine is now in 6th gear. Therefore, it doesn't really make sense to look there, even though the engines are known to cause problems in that area.
What about the pressure side of the charger? Intercooler hose leaking, intercooler has a crack, etc.
That would explain it; there's a loss of charge air, which means there's less oxygen in the exhaust, and that, in turn, results in poorer throttle response.
MrMcFly79
Post04-06-2019, 11:48    Subject: Quote
You're right, I could always try printing a test page.
"...however, the boost pressure and air mass are within the specified range, so a leak should be ruled out?"
dleds
Post04-06-2019, 12:10    Subject: Quote
Does this problem also occur in the lower levels?
If the boost pressure is okay, what about the charge air temperatures?
Is it possible to detect "weather sensitivity"?
MrMcFly79
Post04-06-2019, 12:21    Subject: Quote
Yes, the values are above the target values throughout the entire speed range. I haven't explicitly checked the temperature yet, but the problem is not weather-dependent.
dleds
Post06-06-2019, 11:09    Subject: Quote
Then it would likely produce smoke or soot, and the exhaust would appear cloudy, if you accelerate in second gear while having air mass and boost pressure without generating power. Assuming, of course, that there are no errors in the system and that the injection start time, as you mentioned, is correct (which I assume is the case, since the problem only occurs in certain gears).
What are the fuel injection amounts at full acceleration in 2nd gear compared to 4th gear? They should be the same. If that is not the case, then it is necessary to determine which parameter is causing the reduction in the lower gears.
MrMcFly79
Post28-06-2019, 0:18    Subject: Quote
Okay, so I've installed the new injectors. And sure enough, it now pulls much better from low RPMs and has more overall power. The acceleration from 2000 to 4000 RPM in 3rd gear has improved from 5.8 to 5.3 seconds.
MrMcFly79
Post12-07-2019, 10:45    Subject: Quote
So, it seems the nozzles definitely have a higher flow rate.
I also took some new K-Power measurements, covering the same route there and back.
The injectors installed are Firad DSLA142P1025, and according to Dieselsend and my research, these are the correct injectors for my engine.
Can someone shed some light on this?
Okay, I'm not upset about it. It accelerates really well. The slightest bit of smoke is only visible in the second gear at high RPMs under full load, and only in the rearview mirror.
 File size:  18.47 KB
 Viewed:  263 times
 File size:  22.14 KB
 Viewed:  222 times
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A2 Document: Tapping Noises Below 1600 RPM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Screenshot unter Windows erstellen und posten General Tips
No new posts 1.4 TDI AMF: Turbocharger boost only from 2800 RPM Diesel Engine Technology
No new posts Audi A3 1.9 TDI 130 PS keine Leistung bis 2800 U/min Diesel Engine Technology
No new posts Leistungsproblem, Aussetzer an Pajero 2800 TD Diesel Engine Technology
No new posts 1Z Performance Gap: Analysis & Solutions Diesel Engine Technology
