does not exist | Posts 16+
Go to page: Previous  1, 2
Karma: +1347 / -0   Thank you, like it!
Post28-11-2017, 19:46    Subject: does not exist Quote
Wie man das Getriebe zerlegt und zusammenbaut steht in der ELSA. Die Frage ist was macht die Seat Werkstatt tatsächlich?
I know that too.
You are the one raising the issue with the bearing. The question is whether that bearing is actually removed and installed when a housing half is taken off, or if the problem doesn't even exist. To reseal the housing halves, you don't have to disassemble the gearbox into its individual components.
What needs to be done is stated in the ELSA icon_idea.gif.
Translated on 11-07-2026, 10:05.
kiter
2015 Seat Leon
Post28-11-2017, 20:45    Subject: does not exist Quote
I would like to know what I should pay attention to after the repair. Or whether one simply accepts the minimal oil leak to avoid expensive problems caused by the repair.
I want to drive the car for at least 250,000 kilometers.
Post28-11-2017, 21:24    Subject: does not exist Quote
I wanted to know what I should pay attention to after the repair.
Oil leak.
Let's be clear: either you genuinely understand the critical part of the repair and discuss it with the workshop, or you're exaggerating a problem that doesn't exist. Then the workshop will take that very seriously.
If you can't provide any more information about the assembly of the special bearing, then we should probably end the discussion here.
kiter
2015 Seat Leon
Post02-01-2018, 18:00    Subject: Transmission Quote
The critical step after the ELSA procedure is to heat the transmission housing for 10 minutes to a temperature of 100 degrees Celsius, so that the roller bearing does not get damaged during reassembly.
I'm going to put 50 euros into the tip jar and mention that I appreciated the warming, hoping everything goes smoothly.
The repair will be carried out on January 8th. I will provide an update.
Translated on 11-07-2026, 10:06.
kiter
2015 Seat Leon
dieselschrauber likes this.
Post12-01-2018, 19:35    Subject: transmission; gearbox; gears Quote
The repair was successfully completed without any further issues. I will report back on how it's doing after 5000 km.
Translated on 11-07-2026, 10:07.
kiter
2015 Seat Leon
Post22-07-2019, 13:50    Subject: does not exist Quote
After the transmission was resealed, there was a year of peace. Now, in 2019, it's leaking again, but only very slightly. I had expected something like that. I've now sealed it from the outside with epoxy resin. It should last as long as the Ibiza.
huebi likes this.
Post22-07-2019, 18:00    Subject: does not exist Quote
How does that work? (I know, that's a silly question.) I can only imagine putting a sticker over it.
kiter
2015 Seat Leon
guste100, Herbert and huebi likes this.
Post15-06-2026, 15:01    Subject: does not exist Quote
@HerbertViewing profile: Herbert
Yes, it's "glued over" and it's still holding up to this day, in 2026!
No new posts Document A4 8E Diesel with 5-speed manual transmission: O... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Gearbox Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Manual transmission, Difficult to shift gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine-Gearbox Flange: Slight Oil Leak Diesel Engine Technology
No new posts Golf 4 leaking at the A-pillar (4-door) Transmission, Chassis, Body & Interior
No new posts Fuel injection pump for Volkswagen Golf 2 is leaking at t... Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
