Porsche PoCOM Service Intervals
fam.achilles.papi
Post13-07-2019, 17:37    Subject: Porsche PoCOM Service Intervals Quote
Good evening, I searched in the forum for information on resetting the service interval using the PoCOM, but unfortunately, I didn't find anything. Perhaps someone can help me. Thank you. icon_smile_thumb_up.gif
Translated on 13-10-2026, 20:22.
Post13-07-2019, 18:31    Subject: Porsche PoCOM Service Intervals Quote
What vehicle are we talking about? The service reset is performed in the instrument cluster.
Do you have a Screenshot of the available features in your car?
fam.achilles.papi
Post14-07-2019, 22:12    Subject: Porsche PoCOM Service Intervals Quote
Hello and thank you, Rainer, for the quick response.
This is a Porsche Cayenne 4.2 TDI, manufactured in 2013 (Porsche Cayenne (2011-2018) [958, E2] according to PoCOM). However, I only have the PoCOM unit, including the 16-pin connector, and not an external instrument cluster.
"Thank you."
 File size:  125.49 KB
 Viewed:  2371 times
 File size:  164.04 KB
 Viewed:  1934 times
 File size:  97.58 KB
 Viewed:  1901 times
Translated on 13-10-2026, 20:23.
Post15-07-2019, 19:04    Subject: Porsche PoCOM Service Intervals Quote
Hello.
Do you have a Screenshot of the available options for your car?
from the PoCOM display in the instrument cluster... According to the manufacturer, this can be configured in your car's instrument cluster via coding.
Translated on 13-10-2026, 20:24.
fam.achilles.papi
Post15-07-2019, 21:41    Subject: Porsche PoCOM Service Intervals Quote
I found it, but I can't seem to code it.
Below are some photos:
 File size:  82.7 KB
 Viewed:  641 times
 File size:  60.5 KB
 Viewed:  663 times
 File size:  94.35 KB
 Viewed:  373 times
Post16-07-2019, 18:00    Subject: Porsche PoCOM Service Intervals Quote
Okay, I have contacted the manufacturer of the diagnostic software.
Translated on 13-10-2026, 20:25.
Post17-07-2019, 17:46    Subject: Porsche PoCOM Service Intervals Quote
Hi Rainer,
This code has been tested multiple times in this control unit. It should work. Please, we need two files:
1. Screenshot of instrument control unit: Connect to the control unit, go to the identification section, and click "Save ECU information."
2. Debug log from service reset - Perform the service reset again. When an error message appears, go back to the main menu, settings, and click "save debug."
Sure.
With these two files, we are able to resolve this issue.
"Hello Rainer,
This encoding in this control unit has been tested many times. It should work. Please, we need two files:
1. Snapshot of the instrument control unit: Connect to the control unit, proceed to the identification screen, and click "Save ECU information."
2. Debug log from service reset - Perform the service reset again. If an error message appears, return to the main menu, go to settings, and click "Save debug".
Thank you.
With these two files, we can solve this problem.
Translated on 13-10-2026, 20:26.
Post23-07-2019, 16:33    Subject: Porsche PoCOM Service Intervals Quote
Hi Rainer,
Please download the latest version of pocom. It should work now. There was a bug for a specific type of control unit.
Translated on 13-10-2026, 20:28.
fam.achilles.papi
dieselschrauber likes this.
Post30-07-2019, 10:38    Subject: Porsche PoCOM Service Intervals Quote
Everything is working now! Thank you very much.
Translated on 13-10-2026, 20:29.
Post30-07-2019, 17:29    Subject: Porsche PoCOM Service Intervals Quote
No new posts Used Porsche Mileage: What to Look For General Tips
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Service Interval Display / Maintenance Indicator Technical Data
No new posts Porsche Diagnostics: New PoCOM System On-Board Diagnostics (OBD)
No new posts vag-com and service interval indicator Diesel Engine Technology
This topic is locked, you cannot edit or reply. Resetting the service interval on an Audi A3 8P On-Board Diagnostics (OBD)
No new posts Regarding the variable service interval again Diesel Engine Technology
