HEX-NET Firmware update Server not reachable
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
boss
Post09-08-2019, 8:09    Subject: HEX-NET Firmware update Server not reachable Quote
I have been trying to update my hex-net interface for three days without success. It always ends with the same error:
I have tried temporarily disabling the firewall, antivirus, and web protection. I also disconnected and reconnected the interface, but nothing worked.hex-net
Karma: +781 / -0   Thank you, like it!
Post09-08-2019, 8:22    Subject: HEX-NET Firmware update Server not reachable Quote
What's a bit irritating is that it only shows "HN" in the dropdown, without the interface number.
The update server is operated directly by Ross-Tech. Please contact them directly (Contact information in the menu on their website).
Best regards, Rainer
boss
Post09-08-2019, 12:04    Subject: HEX-NET Firmware update Server not reachable Quote
Hello again and thank you for the quick response.
I have obscured the number. I sent an email to ross-tech this morning, but I haven't heard back yet. I need the interface, actually I need it already. I probably need to downgrade the software in order to be able to use it at all.
Karma: +1318 / -0   Thank you, like it!
Post09-08-2019, 20:03    Subject: HEX-NET Firmware update Server not reachable Quote
We had a problem in the spring with my HEX-V2 interface, which could only be upgraded with the very latest VCDS software. Since then, everything has been fine.
The connection to the server seemed somewhat "random". Perhaps it's similar for you. The application software itself is good.
Post10-08-2019, 10:21    Subject: HEX-NET Firmware update Server not reachable Quote
According to Ross-Tech, there was a severe storm with damaged lines, etc.
The public connection there seems a bit risky to me. Fortunately, such situations do not exist here. icon_cool.gif
Update: Should now be working again.
No new posts DPF regeneriert nicht Troubleshooting & Guides
No new posts 2.7l V6 CR-TDI, Anpassungskanäle funktionieren nicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Schwache Leistung==> nicht LLM! Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zeitaufwand Firmware/Software-update? Diesel Engine Technology
No new posts Steering column lock inaccessible Electrical Systems, Vehicle Electronics, Multimedia
No new posts A7 4K: Steuergeräte not reachable & data bus error On-Board Diagnostics (OBD)
No new posts Steuergerät 46 plötzlich nicht mehr erreichbar On-Board Diagnostics (OBD)
