Oil Pressure Warning Light: Early Deactivation?
T3-TDI-Sporter
Post20-06-2002, 2:21    Subject: Oil Pressure Warning Light: Early Deactivation? Quote
'On my 1Z engine, the oil pressure warning light only stays on for a fraction of a second and then goes out before the engine even starts. The LED must be working fine. Does anyone have any ideas?'
Best regards, T3.
Translated on 02-10-2026, 1:38.
Rudi
Post20-06-2002, 8:49    Subject: Oil Pressure Warning Light: Early Deactivation? Quote
Hi T3 icon_redface.gif,
Did you measure the switch?
If the LED is not directly connected to the switch, it may briefly light up (perhaps for a self-test) when the switch is turned on, and then turn off as soon as the oil pressure switch closes.
If there's a short circuit now, it should immediately turn off again.
Translated on 02-10-2026, 1:39.
No new posts Early 1Z Injection in LL/TL: Troubleshooting On-Board Diagnostics (OBD)
No new posts Start of AEL funding - Early value maximization? Diesel Engine Technology
No new posts Car Engine Cuts Out Early: Troubleshooting Tips Diesel Engine Technology
