Reduce engine wear with magnetic oil drain plug (Solution)
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » General Tips
Post09-02-2020, 13:37    Subject: Reduce engine wear with magnetic oil drain plug Quote
Many modern engines no longer have a magnetic oil drain plug. Actually, modern engines (usually) have become more durable, and there is less wear and tear in the engine oil.
Nevertheless, the very simple and inexpensive replacement of the oil drain screw with one featuring magnets is a measure that can, in a preventative manner, reduce engine wear.
Additionally, this provides an early warning system for engine problems, as a large amount of debris found on the magnet during an oil change indicates that something is wrong.
Therefore, I highly recommend it.
Best regards, Rainer
You are not permitted to view these file(s), please log in or register for extended rights or status updates.
Ratings - Reduce engine wear with magnetic oil drain plug
No new posts Reduce torque On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Anregung - Wir senken den Benzinpreis! Transmission, Chassis, Body & Interior
No new posts Reduce MSW: Disassemble or Lower Injection Amount On-Board Diagnostics (OBD)
No new posts Nano-Additiv soll den Kraftstoffverbrauch signifikant senken Transmission, Chassis, Body & Interior
