VW LT46 Won't Start? Troubleshooting Guide
suzuki14
Post20-03-2020, 8:52    Subject: VW LT46 Won't Start? Troubleshooting Guide Quote
"Hi everyone, I'm having a small problem with my LT46. It suddenly stopped responding to the accelerator pedal; it's now in a limp mode with an idle speed of 1200 RPM. I've already replaced the throttle position sensor (TPS) without success. I've checked the wiring from the TPS to the engine control unit (ECU) for continuity and damage, but I can't find anything wrong. Is there a way to test the throttle body without an oscilloscope? I'm worried that the new or used throttle body might also be defective, or that the ECU itself is faulty. Thanks in advance for any help."
 File size:  2.94 MB
 Viewed:  431 times
pic-779534235e74ac276b9a2-Nmkjbn
 File size:  3.06 KB
 Viewed:  383 times
 File size:  2.98 MB
 Viewed:  570 times
 File size:  2.98 MB
 Viewed:  395 times
 File size:  3.81 MB
 Viewed:  431 times
 File size:  3.24 MB
 Viewed:  453 times
Translated on 06-09-2026, 12:05.
Post20-03-2020, 12:21    Subject: VW LT46 Won't Start? Troubleshooting Guide Quote
Which engine are we talking about? I think there's a misunderstanding here, namely that all the readers of this post are supposed to be clairvoyant...
Translated on 06-09-2026, 12:06.
Post20-03-2020, 14:15    Subject: VW LT46 Won't Start? Troubleshooting Guide Quote
Using VCDS and the appropriate adapter (VW to MB Sprinter), it should be possible to do this within the corresponding vehicle diagnostic system.
suzuki14
Post20-03-2020, 14:54    Subject: No Success: Reasons and Solutions Quote
He's spitting out gas regulators, but they've been replaced. Does it need to be re-calibrated, or is that unlikely?
Translated on 06-09-2026, 12:07.
Post20-03-2020, 16:00    Subject: VW LT46 Won't Start? Troubleshooting Guide Quote
Check if the measurement blocks are working!
From 0% to 100%, depending on the gas level.
suzuki14
Post20-03-2020, 16:36    Subject: No Success: Reasons and Solutions Quote
"Stays at 0, emergency mode remains active... could this be related to the safety box under the steering wheel? See pictures above. But as I've measured, the cables only go from the sensor to the control unit, and from the control unit to the pump. Sorry if I'm wrong, I'm still an apprentice. icon_biggrin.gif Anyway, I've checked all the cables for continuity, and the control unit seems to not be receiving signals from the sensor (gas pedal). I've already installed two other sensors without success...?"
Translated on 06-09-2026, 12:08.
Karma: +1344 / -0   Thank you, like it!
Post20-03-2020, 18:49    Subject: VW LT46 Won't Start? Troubleshooting Guide Quote
dieselschrauber wrote:
Which engine, exactly? I think there's a misunderstanding here, namely that all the readers of the post are clairvoyant...
What is this about? I also don't see any explanation yet, just fragments. Slowly, you start to understand what's depicted in the pictures.
Translated on 06-09-2026, 12:09.
