Säcklein
15-12-2008, 19:34 Subject: VP37 Pump Pinout: Diagram & Information |
Hello.
Can someone tell me the pinout for VP37 pumps?
I know there are x different versions of it, with more or fewer pins.
Please write down what you know!
It would also be helpful to know which actors and sensors are involved.
As far as I know:
- Electric chock.
- PWM signal for proportional control valve.
- Quantity setting device position indicator.
- PWM signal for nozzle control.
Did I forget something?
Why do some pumps have 8 pins and others have 10? What do the two additional pins do?
As I mentioned, pin striping would be really great!
Okay, here's the translation:
Thank you.
Chris.
Translated on 13-10-2026, 21:54.
Boro Guest
16-12-2008, 11:11 Subject: VP37 Pump Pinout: Diagram & Information |
Sure, here's the translation:
'Just for understanding...'
Some pumps (models ending in 'A') have an 8-pin connector (with 7 pins used) and an additional 3-pin connector.
In the other pumps (models ending in 'B'), instead of the two connectors, a single 10-pin connector was installed.
Translated on 13-10-2026, 21:55.
16-12-2008, 11:31 Subject: VP37 Pump Pinout: Diagram & Information |
"Just another piece of information:"
8Pol == old (Golf3 era)
10-pin (new, starting with Golf 4) (although "new" is relative, as there are no new VAG pumps anymore).
m; Transparency, Teamwork
Translated on 13-10-2026, 21:56.
Profile PM Garage |
Säcklein
16-12-2008, 16:15 Subject: VP37 Pump Pinout: Diagram & Information |
Hello.
"Thank you, that's already helpful."
Does anyone have any idea what the pinout looks like for a Golf 4, for example?
"Could someone possibly tell me what the voltage levels of the PWM signals from the injection control unit and the mass flow actuator are? Are they running at 12V or 5V...? And what is the frequency?"
Chris.
Translated on 13-10-2026, 21:57.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
05-05-2020, 18:14 Subject: VP37 Pump Pinout: Diagram & Information |
/viewtopic.php?t=1585&highlight=pumpenstecker
Translated on 13-10-2026, 21:58.
Profile PM WWW Garage |
