Measurement Blocks: Grey Color Options
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Uwe
Post21-05-2020, 6:27    Subject: Measurement Blocks: Grey Color Options Quote
"On the Golf VII, error codes and other data can be accessed, but not measurement blocks. The button is grayed out and, of course, cannot be clicked. Older vehicles also had problems accessing the control units."
What am I doing wrong?
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 25-07-2026, 1:01.
Karma: +1336 / -0   Thank you, like it!
dieselschrauber likes this.
Post21-05-2020, 9:39    Subject: Measurement Blocks: Grey Color Options Quote
Hi there,
"The control units (ECUs) in newer vehicles typically no longer have measurement value blocks; they only offer extended measurement values. You can configure sentences containing up to 13 individual values yourself. In the case of the Golf 7 (and other models), it's also worth noting that not all ECUs and functions are accessible with the HEX-USB+CAN interface."
Translated on 25-07-2026, 1:02.
Uwe
Herbert likes this.
Post21-05-2020, 9:49    Subject: Measurement Blocks: Grey Color Options Quote
I have the HEX V2. I'll check later to see if I can access the extended measurement data.
I also tried to read the mileage data from the engine control unit, but unfortunately it didn't work; I got an error message.
Translated on 25-07-2026, 1:03.
Herbert likes this.
Post21-05-2020, 10:43    Subject: Measurement Blocks: Grey Color Options Quote
Uwe wrote:
I also tried to read the mileage of the engine control unit. Unfortunately, it doesn't work; I get an error message.
Is for EDC15/EDC16 engine control units...
Translated on 25-07-2026, 1:04.
Uwe
Post21-05-2020, 11:09    Subject: Measurement Blocks: Grey Color Options Translating...
[Translating...]
No new posts Gibt es für AAT Solldaten der Meßwertblöcke ? Diesel Engine Technology
No new posts Meßwertblöcke für 1.8 turbo gesucht (Off Topic) Diesel Engine Technology
No new posts Audi A4: White/Gray Smoke - What Causes It? Diesel Engine Technology
No new posts Messwerte grau hinterlegt in VCDS On-Board Diagnostics (OBD)
