Coolant Change with VCDS: How-To Guide
dennis91
Post07-12-2020, 14:39    Subject: Coolant Change with VCDS: How-To Guide Quote
Hello everyone,
More and more often, I'm reading that the Volkswagen Group no longer uses G13 coolant because, supposedly, it causes damage over time due to corrosion in the heat exchanger and radiator. A friend of mine who helped develop VW engines pointed this out to me and also asked a simple question: Does it sometimes smell like antifreeze coming from the engine compartment?
And I have to say, unfortunately yes, even though nothing is leaking.
Therefore, VW only uses G12evo in new vehicles. However, the G13 is not replaced during a service. That's why I wanted to do it myself. While some people recommend using the older method of fully heating up the engine and bringing it to operating temperature, the workshop manual for the Golf 7 1.6 TDI states that it should be done via diagnostics. In VCDS, there is an option called "Bleed cooling system." Has anyone here already done this?
Translated on 24-08-2026, 5:04.
vag-driver
dieselschrauber likes this.
Post10-12-2020, 10:25    Subject: Coolant Change with VCDS: How-To Guide Quote
I have already started a thread to discuss the topic of G13.
At Volkswagen, the G13 coolant is still being used. According to a parts service employee, the G12evo coolant is only required for the very latest vehicles within the group.
Andreas
Translated on 24-08-2026, 5:06.
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Werkstattaktion 2D, Glühkerzen-STG tauschen Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Öl im Kühlwasser Diesel Engine Technology
No new posts Coolant Thermostat: Buy Online & Save! Diesel Engine Technology
No new posts Öl im Kühlwasser beim B4 mit 1Z Diesel Engine Technology
No new posts Glow plugs for coolant Diesel Engine Technology
