Seltsame Aschewerte an 1.6 TDI
chli1976
dieselschrauber likes this.
Post21-12-2020, 17:01    Subject: Quote
Caddy 1.6 CAYE with 122,780 km came to me because the regeneration system was not working correctly, and these were the values after a service regeneration.
IDE00427-ENG101722 Particle filter: Differential pressure - DIP_PF 4.48 hPa
IDE00430-ENG102682 Particle filter: Field regeneration Requirement status-STATE_RGN_PF 0
IDE00433-ENG103279 Particle filter: Oil ash volume - MASS_ASH_PF 5.6297655 g
IDE00434-ENG102050 Particle filter: Soot mass calculated - MASS_SOOT_SIM_PF 22.94 g
IDE00435-ENG101197 Particle filter: Soot mass measured - MASS_SOOT_PHY_PF -5.16 g
IDE00436-ENG102397 Particulate filter: Kilometers since last regeneration - DIST_RGN 6.2 km
Someone messed with the settings again, so I adjusted the ash mass to 33 grams now, and it should work again.
I still need to do a test drive and then check the particulate mass again, which is currently at 0.00.
VCDS
Translated on 07-09-2026, 5:40.
No new posts Strange readings Diesel Engine Technology
No new posts Strange Factory Details: Unexplained Facts Diesel Engine Technology
No new posts Strange Coding in MSG On-Board Diagnostics (OBD)
No new posts Strange Error Combination: Troubleshooting Guide On-Board Diagnostics (OBD)
