dennis91 wrote: |
| Shouldn't the oil ash mass and oil ash volume have smaller values after regeneration? Only the calculated and measured soot mass have decreased. |
Counter-question: What happens during regeneration?
During the regeneration process, the soot burns and turns into ash. This means that after regeneration, the soot should be gone, while the amount of ash should increase slightly. However, this increase in ash is so small and the resolution of the display is so low that you won't be able to see it on the display.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
