dennis91
Joined: 07/01/2017 Posts: 50 Karma: +10 / -0 Location: Igensdorf
dieselschrauber likes this. |
20-01-2021, 16:26 Subject: |
VW Passat B8, 2.0 TDI, 75550 km.
The values were recorded once directly before the regeneration and once 1 kilometer after the regeneration.
| Description: |
| File size: |
646.4 KB |
| Viewed: |
2866 times |
Translated on 20-07-2026, 19:08.
wolle Blaumann
05-04-2021, 17:27 Subject: Audi A6 Bi-TDI from 2018, 320HP CVUC conversion |
Hello everyone,
During my searches today regarding fuel rail pressure, etc., I found the following...
Therefore, I would appreciate a response.
Audi A6 Avant Allroad from February 2018 with CVUC engine, 3.0 TDI, 320 hp.
Mileage: 71,000 km. Purchased recently at 62,500 km.
Current fill level: 0.04L, which is 40ml.
Best regards from the LüHei team.
Wool.
Translated on 20-07-2026, 19:09.
peter21
07-08-2021, 11:13 Subject: |
Hello everyone,
I have a Skoda Octavia 1Z from 2007.
BLS engine, 1.9 TDI.
Mileage: 240,000 km
Filling: 63g (Maximum allowed is 60g).
Peter.
Translated on 20-07-2026, 19:10.
Schneemann Blaumann
Joined: 08/09/2003 Posts: 78 Karma: +2 / -0 Location: Wissen
19-09-2021, 11:45 Subject: |
Greetings.
Golf Plus, CFHC 2.0L 140 hp, Model 2011.
at 120,000 km, 0.06 liters.
at 142,000 km, 0.08 liters.
at 160,000 km, 0.09 liters.
at 172,000 km, 0.10 liters.
at 177,000 km, 0.10 liters.
Maximum fill level, as far as I know, is 0.175 liters.
AGR disabled at 120,000 (if relevant).
Gruß Schneemann
Golf Plus Highline Bj. 09/2010 CFHC. eFH, eSP, Climatronic, PDC, AHK, ABS, ESP, GRA, MFA, LMAA, FDH, BSE, Brenderup Kippi 200 und ne Traumfrau auf dem Beifahrersitz.
Translated on 20-07-2026, 19:12.
playzocker22
Joined: 09/23/2021 Posts: 6 Karma: +6 / -0 Location: Stade
12-10-2021, 8:37 Subject: |
Audi A4 B8 2.0 TDI CNHA, optimized from 190 hp to 215 hp.
At 225,000 km: 0.18 liters and 72 grams of ash content.
DPF cleaned, now running smoothly with 232,000 km on the odometer.
Translated on 20-07-2026, 19:14.
stranger1603
01-11-2021, 16:15 Subject: 272,000 with the First DPF?!? |
Golf Variant 2.0 TDI CFHC, 140 hp, manufactured in 2012, with 272,000 km mileage.
0.14 liters
"I bought a car with 140,000 km on the odometer, so I have no idea whether the DPF (Diesel Particulate Filter) has ever been cleaned or reset."
The differential pressure and exhaust backpressure readings appear to be within acceptable limits when checked with the OBD system (approximately 20 mbar before/5 mbar after the catalytic converter).
If it reaches a value of 0.175, it will simply be reset using the VAG system, and the pressure difference in the eye will be monitored.
Different.
Translated on 20-07-2026, 19:15.
chli1976 Profi-Schrauber
01-11-2021, 19:08 Subject: Re: 272,000 with the First DPF?!? |
stranger1603 wrote: |
Different |
Not a good idea; you'll likely have problems with recovery afterward.
VCDS
Translated on 20-07-2026, 19:17.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
18-09-2022, 16:25 Subject: |
T6, 110kW TDI, mileage 105,726 km.
Oil residue: 34.98g
Limit oil ash content: 110.00g
Translated on 20-07-2026, 19:18.
Profile PM WWW Garage |
Moritz-Axtmann
03-10-2022, 11:07 Subject: Hello everyone! |
A4 3.0 TDI - Engine code CDUC, 315074 km, oil ash volume 0.40 l. Filter was just replaced. The maximum load limit is probably 0.37 l. This P242F 00 [039] error – "Maximum loading exceeded" – was detected during the oil change. The MIL (Malfunction Indicator Lamp) was not illuminated.
E30_V8 Profi-Schrauber
Joined: 06/15/2022 Posts: 94 Karma: +111 / -0 Location: ...aus dem Herzen der Natur! 2005 Skoda Fabia  Premium Support
18-11-2022, 8:24 Subject: |
Volkswagen Polo 6R, 1.6 TDI with 105 hp, manufactured in 2010, engine code: CAY.
Mileage: 165,000 km (the last 45,000 km were mostly long-distance driving).
Oil residue: 40.2g
Limit oil ash content: 70g.
Polo V 1,6 Tdi (CAY)
Translated on 20-07-2026, 19:19.
Profile PM Garage |
Servant
19-11-2022, 15:56 Subject: |
Sharan 7N2 Model 2017 - 2.0 TDI 150HP (Engine Code: DFLA) DSG - 98,000 km - Oil ash mass: 30.2 g, loading limit: 80 g.
Translated on 20-07-2026, 19:20.
3bAFN
07-01-2023, 12:57 Subject: |
Polo 9N3, 1.4 TDI BWB, 70 hp, 230,589 km, 50g (presumably referring to emissions).
Translated on 20-07-2026, 19:21.
safedriver
Joined: 10/14/2016 Posts: 11 Karma: +1 / -0 Location: Österreich - Kärnten 2002 Volkswagen Passat Premium Support
17-08-2023, 14:48 Subject: |
Skoda Octavia 5E Facelift, 4x4, Year: 2018.
Engine code: CRMB 2.0 TDI 150 hp.
KM: 239160 (mostly long distance).
Oil ash content: 61g.
Limit: 80g.
Oil consumption: approximately 1 liter per 10,000 kilometers since the beginning.
It now regenerates approximately every 70 to 90 kilometers... The soot mass jumps from 9 grams to 22 grams.
Skoda Ovtavia 5E Combi Style 4x4 2.0 TDi CRMB 150PS Euro 6 ohne SCR-Kat; BJ 2018
VW Passat 3BG Variant Highline; 1.9 TDI-PD 101PS; MKB: AVB; GKB: EEN; Umbau auf EMS(Valeo 4KKit)
Translated on 20-07-2026, 19:22.
Profile PM Garage |
Herbert Profi-Schrauber
15-09-2023, 17:59 Subject: |
Horch A4, CJCD engine, mileage: 180,000 km, oil ash content: 53.1 g or 0.12 liters (limit: 0.175 liters).
The ash content value for the vehicle/engine is evidently a calculated value that depends on mileage. Resetting would be done in units of kilometers (or miles).
Translated on 20-07-2026, 19:23.
charmillo
2005 Audi A6 Avant Premium Support
08-12-2023, 15:18 Subject: |
Those are the values I have.
Audi A6 Avant 3.0 TDI, model 4F, year 2005.
BMK 225 hp.
252,000 km - 51 g
Translated on 20-07-2026, 19:24.
Profile PM Garage |
Stefan-5E5
2013 Skoda Octavia Premium Support
16-02-2025, 17:59 Subject: |
Oil ash volume: 0.17 L.
Oil residue: 68.2g (limit 80g).
Mileage: 276,000 km
Fuel consumption with winter tires: 6.0 L/100km.
CKFC engine in a Skoda Octavia 3 4x4.
Original: 150 hp / 320 Nm
Tuned at 140,000 km. Power output: 180 hp / 400 Nm of torque.
Skoda Oktavia 3, 4x4, CKFC, Serie 150Ps/320Nm, Chip ca. 180PS/400Nm.
Translated on 20-07-2026, 19:25.
Profile PM Garage |
