DPF Differenzdruck Normwerte | Posts 32+
Go to page: Previous  1, 2, 3
Karma: +1336 / -0   Thank you, like it!
dieselschrauber likes this.
Post23-05-2021, 6:27    Subject: Quote
A4 8K, CJCD, Mileage approximately 140 Tkm, Freshly regenerated:
Differential Pressure:
- 2 hPa at 0 min-1, Offset 1 hPa
- 26 hPa at 1500 min-1 (Full throttle, DPF 276 °C, air mass flow 56 g/s, boost pressure 1755 hPa)
- 150 hPa at 4000 min-1 (Full throttle, DPF 488 °C, air mass flow 152 g/s, boost pressure 2330 hPa)
Volume: 0.09 l (39.5g) with a limit of 0.175 l.
Post15-09-2023, 19:09    Subject: Quote
A4 8K, CJCD, Odometer: 180 Tkm, Freshly Regenerated:
at 5 hPa, offset 1 hPa
at 3 full-throttle runs in 4th, 5th, and 4th gear Gang:
- around 30 hPa at 1500 min-1;
- around 190 hPa at 4000 min-1.
Volume: 0.12 l (53.1 g) with a limit of 0.175 l.
Post05-11-2024, 15:23    Subject: Quote
A4 8K, Mileage: 199700 km, Recently refurbished:
Idle 9 hPa (after 3 measurements), Offset 0hPa
at 3 full throttle runs: 5th gear:
- around 190 - 200 hPa at 4000 min-1.
Consumed 56.6 g (0.14 l) at a limit of 0.175 l.
After the previous service regeneration trip, the soot mass values (measured and calculated) are finally identical, with no decimal places. Previously, the difference was 8 g (calculated > measured). Due to the high calculated value, regenerations had become more frequent.
Post14-10-2025, 12:01    Subject: Quote
VW T5
MKB CAAC
150.000km
Last regeneration at 130km
max. Differential pressure at 3600 rpm: 195 hPa
No new posts P244B - Diesel Particulate Filter - Differential Pressure... General Tips
No new posts P244B Diesel Particulate Filter Differential Pressure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure DPF vs. exhaust backpressure (and S... Diesel Engine Technology
No new posts DPF differential pressure slightly high Diesel Engine Technology
No new posts Differential Pressure & Backpressure: 3.0 TDI Comparison Diesel Engine Technology
No new posts Where is the differential pressure sensor located? Diesel Engine Technology
