OBD2 Check: No Connection to VW T5 Multivan?
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
On-Board Diagnostics (OBD)
View previous topic
View next topic
Author
Message
Can2021
Subject: OBD2 Check: No Connection to VW T5 Multivan?
Quote
I'm trying to read error codes from a VW Multivan T5...
First registration: 07/2008.
KOBD2Check V1.90 Scan, 20210709-073844
http://shop.dieselschrauber.org/en
Reading vehicle information...
Reading error codes...
Surgery failed.
THANK YOU for your help...
Alex.
Translated on 21-08-2026, 15:05.
Profile
PM
2018 Volkswagen T6
09-07-2021, 6:51
Subject: T5 Multivan: KOBD2Check connection issues?
Quote
Can2021 wrote:
I am trying to read error codes from a VW Multivan T5...
Surgery failed.
Alex
Hello Alex,
It's quite likely that your VW T5 uses a K-line instead of a CAN bus for the OBD2 interface. The manufacturer's own diagnostic system probably runs over CAN, but that won't be helpful to you.
The preferred method for this vehicle would be VCDS:
https://shop.dieselschrauber.org/en/vcds-hex-v2-p-329.php
Dipl.-Ing. (FH) Rainer Kaufmann -
Original VCDS mit KPower, KDataScope und Dieselschrauber Support
Translated on 21-08-2026, 15:07.
Profile
PM
WWW
Garage
New Topic
Reply
View previous topic
View next topic
Topic
Forum
Automatic Transmission: No Rebuild Needed (01K-01F)
A4 8E2/8E5 - Possible various error memory messages
Is it possible to install a G40 engine without replacing ...
Vagcom303: No Connection to 1Z B4 - Troubleshooting
HEX-NET: No Wi-Fi connection
VAG-COM fails to connect
VAG COM: No Connection T5 2008 (German)
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.056s
