Caddy 2,0 SDI Steuergerät defekt? | Posts 16+
Go to page: Previous  1, 2
Post22-07-2021, 15:27    Subject: Quote
Shouldn't the engine still start, or at least should the glow plug light illuminate, even if there's a problem with the wiring harness of the CAN drive system?
Yes. Even if communication with the WFS were not possible, it would still need to run for 1-2 seconds.
Does the engine control unit still use a K-line connection in the 2K system?
In addition to the CAN bus, K-Line is also present. Whether it's used for general OBD or specifically for OBD2 varies depending on the model and year of manufacture. Generally, models from 2008 onwards use the CAN bus for OBD2 as well.
"LG" can be translated as "Best regards" or "Sincerely". It is a common abbreviation for "Liebe Grüße", which means "Warm greetings" in English.
Translated on 09-08-2026, 2:10.
3bAFN
Karma: +33 / -0   Thank you, like it!
dieselschrauber likes this.
Post22-07-2021, 19:43    Subject: Quote
A failed jump start attempt due to reversed polarity can be ruled out. It was not even attempted.
I will probably try to arrange a control unit for testing.
I don't see any other options anymore.
I am still grateful for any suggestions or advice you may have.
Translated on 09-08-2026, 2:12.
3bAFN
Post28-07-2021, 21:49    Subject: Quote
The vehicle is running again.
It was actually due to the engine control unit.
Post29-07-2021, 20:01    Subject: Quote
Translated on 09-08-2026, 2:13.
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Are Caddy TDIs with 105 hp and 75 hp identical (except fo... Diesel Engine Technology
No new posts VW Caddy: Read Kilometer Stand from ECU On-Board Diagnostics (OBD)
No new posts Defective Control Unit: What to Do? On-Board Diagnostics (OBD)
No new posts Faulty Control Unit: Diagnosis & Repair On-Board Diagnostics (OBD)
