VCDS Mobile: Incorrect Data Display? Fix Now!
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post12-08-2021, 20:20    Subject: VCDS Mobile: Incorrect Data Display? Fix Now! Quote
With VCDS-Mobile and the HEX-NET interface, it's very easy to check your own vehicle on the go using your mobile phone.
VCDS-Mobile is the diagnostic solution for your own vehicles that can be operated via a web browser within the HEX-NET system.
After scanning the vehicle with a diagnostic tool, update the HEX-NET device using the Windows software and an internet connection. To do this, search for updates within the VCDS configuration tool (VCIConfig.exe).
All the necessary files for each vehicle are uploaded to the HEX-NET system. From that point on, the HEX-NET recognizes the control units in the vehicle, and a comprehensive diagnosis is possible.
Please provide the text you would like me to translate from German to English. I will only provide the translation, without any explanations. Also, please include "Speak also about measured values or extended measured values." in the translation if applicable.
During firmware updates of the HEX-NET device, it may be necessary to clear the "dataset cache" to ensure that the correct measurements are displayed.
In this case, simply click the button in the Screenshot; the cache will then be automatically rebuilt. icon_wink.gif
 File size:  146.45 KB
 Viewed:  496 times
 File size:  182.17 KB
 Viewed:  488 times
 File size:  133.63 KB
 Viewed:  526 times
Translated on 25-07-2026, 11:24.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Doku A2 8Z0 Mj 2002, Bordcomp. zeigt nur Reichweite Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts VCDS Mobile App not in Store On-Board Diagnostics (OBD)
No new posts VCDS Mobile App for Sharan 7N On-Board Diagnostics (OBD)
No new posts Announcements: VCDS-Mobile®, HEX-NET® Interface On-Board Diagnostics (OBD)
No new posts VCDS - Wartungsintervallanzeige zeigt Fehlermeldung On-Board Diagnostics (OBD)
