Hello everyone,
The air distribution flap in our Golf 7 is broken.
"Initially, the car scan showed 'faulty,' but after clearing the error, it displayed 'No zero position.'"
Is the valve calibrated/learned in the same way as the others, using the "default position" and "calibrate valve" options? It doesn't work anymore.
As far as I know, the motor is located between the steering column and the center console. Does anyone have any experience or know how to access the panel? The temperature valve on the right was relatively simple, but what about the V426?
Thank you very much!
Dennis.
| Description: |
| Air distributor flap servo motor |
 Download |
| File name: |
Log----------WVWZZZAUZEW170509-132935km[11482].txt |
| File size: |
12.32 KB |
| Downloaded: |
2098 times |
