Passat B6 1.9 TDI: Starting Problems & Solutions
Kputt83
Post08-08-2021, 14:42    Subject: Passat B6 1.9 TDI: Starting Problems & Solutions Quote
Hey everyone.
I'm having a frustrating problem with my B6 1.9Tdi (BLS).
I often experience starting problems, sometimes after a long period of inactivity and sometimes after a very short one.
"Starting problems mean that I have to crank the engine for a longer time or more frequently before it receives fuel and starts."
I initially thought the PD element was leaking, so I replaced all the seals. The problem still persists. I replaced the diesel filter, and then I felt like it was getting better (the filter was also quite old).
After a certain amount of time, I started having the same problem with the engine not starting again. The temperature didn't seem to matter; it wouldn't start at -10 degrees Celsius, just like it wouldn't start at +20 degrees Celsius.
I also replaced the glow plugs, then the tandem pump, and finally, I installed a check valve on the return line from the filter because I noticed that every time the engine was higher than the tank, the problem got worse.
"I left it on my ramps overnight after installing the valve yesterday, and tested it again this morning. It still took a long time to start. Once it's running, though, and I use it daily, I have no starting problems, and it runs perfectly."
Lately, I've been traveling for work, and my B6 has been parked for two weeks at a time (relatively level), and even then, it started poorly, but not as badly as this morning when I parked it "tilted."
Based on the symptoms, it seems like the lines are running dry when the engine is higher than the tank, but where is the source of the problem?
Translated on 30-08-2026, 23:24.
Tobiii
dieselschrauber likes this.
Post09-11-2021, 14:18    Subject: Passat B6 1.9 TDI: Starting Problems & Solutions Quote
Probably, I'm too late with the answer icon_smile.gif.
Option 1: The PDE is internally leaking/worn out.
Option 2: The PDE (power distribution element) has been re-sealed, but there are already signs of leakage around the head, and the sealing is no longer effective.
Would spontaneously come to mind.
aktuelle Diesels:
Audi A6/4b, 2,5Tdi
Toyota HJ61 mit 12HT
VW T5, 1,9PD
VW Golf 4, 19PD
Mercedes T1 208D OM 601
Translated on 30-08-2026, 23:27.
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB 1.9Tdi Upload
No new posts 1.9 TDI Engine Failure: Causes & Solutions Diesel Engine Technology
No new posts 1.9 TDI (AWX): Reduce Compression Ratio Diesel Engine Technology
No new posts Burnt Piston 1.9 TDI AFN Golf 3 Diesel Engine Technology
