CFFB Shakes in Cold Weather
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
3bAFN
Karma: +33 / -0   Thank you, like it!
Post18-11-2021, 14:12    Subject: CFFB Shakes in Cold Weather Quote
Hello everyone,
I have a Golf 6 with the 2.0 TDI CFFB engine.
According to the owner, the engine rattles loudly in the morning when it's cold. After a while, the rattling stops, and it runs normally.
At 10,000 km, this phenomenon also occurred, and as a result, injector 3 was replaced by a workshop.
Here's the log data from this morning's test drive. As usual, the car seemed to be running normally. However, the fuel injection deviation in cylinder 2 is somewhat concerning.
I have also read out and attached the rail pressure calibration points for the injectors.
Can the values indicate whether the problem might be caused by an injector?
Thank you very much.
Sören.
Thursday, November 18, 2021, 12:43:55:23565
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 20.12.0.3
Data as of: 20210211 DS322.1
www.Ross-Tech.de
Vehicle Identification Number: WVWZZZ1KZCW009519 License Plate:
Mileage: 173,850 km. Repair order:
Vehicle type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 20 25 2E 37 42 44 46 52 56 62 69
72 77
Mileage: 173,850 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: Error 0010.
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
High Beam Assist -- Status: OK 0000
Immobilizer system -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
69 followers -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
77-Phone -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module (J623-CFFB)
Label file: .DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018, HW: 03L 907 309 R.
Part: R4 2.0l TDI H23 9982
Revision: 42H23--- Serial number: 00000000000000
Encoding: 00190012042400080000
Operating number: WSC 17242 004 1048576
ASAM Dataset: EV_ECM20TDI01103L906018 003018
ROD: EV_ECM20TDI01103L906018_003_VW36.rod
VCID: 67DBD5C89E31D9BCA1-8032
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics (J104)
Label file: .DRV\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 BJ
Part number HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Encoding: 143B400D09220003281002E590220042310000
Operating number: WSC 01357 011 00200
VCID: 7BF399B8FAB96D5C55-802E
Address 08: Climate Control/Heater (J255)
Label file: | DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 EA, Part number HW: 5K0 907 044 EA.
Component: Climatronic, Part Number: H17 1010.
Revision: 00001003
Encoding: 0000000002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 6ED5A0ECB1CB08F4E2-803A
Address 09: Central Electronics (J519)
Label file: .DRV\1K0-937-08x-09.clb
Part number SW: 1K0 937 086 M, Hardware: 1K0 937 086 M.
Part: BCM PQ35 M 110 0651
Revision: 00110 AC
Encoding: 46180A3F88251AC0400800C8740081E44B711588736D8520648000200040
Operating number: WSC 49123 123 12345
VCID: 3A7D5CBCB50394540E-806E
Subsystem 1 - Part number: 5K1 955 119
Label file: DRV\1KX-955-119.CLB
Part: Wiper 11051 26 0512
Encoding: 009795
Subsystem 2 - Part number: 1K0 955 559 AH
Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 270511 05 54 0403
Encoding: 0230AD
Address 10: Parking Assist 2 (J791)
Label file: .DRV\1T0-919-475.clb
Part number SW: 1T0 919 475 P, HW: 3T0 919 475 C.
Part: PARKING ASSIST PLA H08 0116
Revision: -------- Serial Number: 13991108038368
Encoding: 11800A
VCID: 48993674FBEFF6C488-801C
Address 15: Airbag (J234)
Label file: | DRV\5K0-959-655.clb
Part number SW: 5C0 959 655 D, HW: 5C0 959 655 D.
Component: Airbag VW10G 013 0613
Serial number: 003G7RA0C9CA
Encoding: 00003954
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 336371989A69651CCD-8066
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4E6C0460ZZZ$
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number SW: 5K0 959 354, HW: 5K0 959 354.
Component: S.Sens.Front.Right H01 ----
Serial number: 3582MSME6343615FZZZ.
Rear side airbag crash sensor (driver's side).
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME62140513ZZZD
Crash sensor for rear side airbag, passenger side.
Component: S.Sensor, Passenger Side, Front.
Serial number: 3522QSME48271E4BZZZ0.
Address 16: Steering wheel electronics (J527)
Label file: | DRV\5K0-953-569.clb
Part number SW: 5K0 953 507 BC, HW: 5K0 953 549 E.
Component: Steering module 008 0080.
Revision: -------- Serial Number: 90422KER0005R
Encoding: 1082140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72EDB49CA5F32C1406-8026
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 3C8 959 537 D, HW: 3C8 959 537 D, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-TK6 H06 0022
Serial number: 50000000000000389408
Encoding: E20000
"One error found:"
530190 - Local data bus.
U1030 00 [008] - electrical fault.
Sporadically - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 6
Error frequency: 1.
Lost Count: 119
Mileage: 173,786 km
Date: 2021.11.16
Time: 06:53:39
Address 17: Control panel module (J285)
Label file: | DRV\5K0-920-xxx-17.clb-SRI1
Part number SW: 5K0 920 872 A, Hardware: 5K0 920 872 A.
Component: KOMBI H03 0607
Encoding: 170D00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2D5767E07C4D33EC9B-8078
Address 19: Diagnostic interface (J533)
Label file: .DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 H, HW: 1K0 907 951.
Component: J533 Gateway H42 1620.
Revision: H42
Serial number: 010611F2001134
Encoding: 350002
VCID: 35674F809C1D7B2CE3-8060
Address 20: High Beam Assist (J844)
Label file: .DRV\8K0-857-511.clb
Part number SW: 5K0 857 511 B, HW: 8P0 857 511 C.
Component: FLA H04 0006
Revision: AA001002
Encoding: 01018B6B74745D545420363E00
VCID: 2D5767E0744D33EC9B-8078
Address 25: Immobilizer (J334)
Label file: | DRV\5K0-920-xxx-25.clb
Part number SW: 5K0 953 234
Part number HW: 5K0 953 234
Component: IMMO H03 0607
Encoding: 000000
Operating Number: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
VCID: 6ADDACFC8D23E4D4BE-803E
Address 2E: Media Player 3 (J650)
Label file: .DRV\5N0-035-342.lbl
Part number SW: 5N0 035 342 E, HW: 5N0 035 342 E.
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial Number: 7660060684
Encoding: 020000
VCID: 295F93F040A52FCC77-807C
Address 37: Navigation (J794)
Label file: | DRV\3C0-035-270.clb
Part number SW: 3C0 035 270 B, HW: 3C0 035 270.
Component: RNS310 H19 0357
Revision: 10000000 Serial Number: VWZ1Z2L7229062
Encoding: 040004010400000000000000
ASAM Dataset: VW_RNS310 A02007
ROD: EV_VWRNS310UDS.rod
VCID: 193FA33018C5BF4CE7-804C
Address 42: Door electric driver. Label file: .DRV\1K0-959-701-MAX3.clb
Part number SW: 5K0 959 701 C. Hardware: 5K0 959 701 C.
Component: Door seal 009 2119
Coding: 0004278
VCID: 326D749CAD736C14C6-8066
Address 44: Steering Assist
Label file: DRV\1K0-909-14x-GEN3.clb
Part number: 1K0 909 144 M
Component: EPS_ZFLS, Size 70 3201
Revision: 00H20000
VCID: 3461728457676224D4-8060
Address 52: Door electronics, passenger side. Label file: .DRV\1K0-959-702-MAX3.clb
Part number SW: 5K0 959 702 C. Hardware: 5K0 959 702 C.
Encoding: 0004534
VCID: 336371985269651CCD-8066
Address 62: Door electric, left/right. Label file: .DRV\1K0-959-703-GEN3.clb
Part number SW: 5K0 959 703 D, Part number HW: 5K0 959 703 D.
Component: Door Seal 007 2101
Encoding: 0000144
Operating number: WSC 01357 011 1012552
VCID: 35674F805C1D7B2CE3-8060
Address 69: Trailer (J345) Label file: .DRV\1K0-907-383-V2.clb
Part number SW: 1K0 907 383 F. Hardware: 1K0 907 383 F.
Component: Trailer H09 0100
Revision: 3A001001 Serial Number: 00000145856441
Encoding: 410D000100000000
VCID: 30697E94637F5E04B0-8064
Address 72: Door electric strike, high, right. Label file: .DRV\1K0-959-704-GEN3.clb
Part number SW: 5K0 959 704 D, Part number HW: 5K0 959 704 D.
Encoding: 0000144
VCID: 3665488C411B7034EA-8062
Address 77: Phone (J412)
Label file: | DRV\7P6-035-730.clb
Part number SW: 7P6 035 730 E, Hardware number: 7P6 035 730 E.
Component: TELEPHONE H09 2730
Revision: 1B001001 Serial Number: 00007660063477
Encoding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01015
ROD: UHVNA.rod
VCID: 346172849F676224D4-8060
End----------------------------(Duration: 02:52)-----------------------------
Log-WVWZZZ1KZCW009519.txt
 Raildruckkalibirierpunkt
 File name:  Log-WVWZZZ1KZCW009519.txt
 File size:  1.21 KB
 Downloaded:  447 times
LOG-01-IDE00021_&6.xlsx
 File name:  LOG-01-IDE00021_&6.xlsx
 File size:  26.96 KB
 Downloaded:  275 times
Translated on 20-09-2026, 21:59.
Herbert likes this.
Post18-11-2021, 21:37    Subject: CFFB Shakes in Cold Weather Quote
It is noticeable that two cylinders have a deviation of more than 2 mg/h during idle speed control, while the rail pressure decreases slightly at the same time.
Here's the translation:
"Regarding air leaks (e.g., fuel hoses or diesel filter), I would be looking for anything that could be letting air in, especially if the vehicle has been sitting for a while."
When accelerating at full throttle for several seconds at high RPMs, does the car run with full power without any hesitation or jerking?
Perhaps something is broken somewhere, maybe a plastic part near the fuel lines? The connectors/cables at the pressure regulator valve are okay, and there are also no metal shavings inside the diesel filter (from the high-pressure pump)?
 Kupplungen und Leitungen dicht?
 File size:  1.61 MB
 Viewed:  3780 times
 O-Ring im Deckel des Filters ok und keine SpĂ€ne drin?
 File size:  2.5 MB
 Viewed:  3757 times
 Verschlauchung der Kraftstoffleitungen (RĂŒcklauf) mitsamt den PlastikstĂŒcken (SchlauchanschlĂŒssen)ok?
 File size:  1.95 MB
 Viewed:  3789 times
Translated on 20-09-2026, 22:00.
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post18-11-2021, 23:06    Subject: CFFB Shakes in Cold Weather Quote
The idle stabilization system (which is an injection quantity correction for individual cylinders to ensure a smooth idle) only works at idle speeds up to approximately 1100 RPM. Therefore, recording data while accelerating or decelerating is pointless. It's better to record data in separate sections, both when the engine is cold and when it's warm, and to include the coolant temperature readings.
Translated on 20-09-2026, 22:01.
3bAFN
Post20-11-2021, 20:44    Subject: CFFB Shakes in Cold Weather Quote
I can rule out air leaks. All connections are sealed.
Going full throttle at high speed is perfectly fine.
There were actually very tiny, gold-colored shavings in the diesel filter.
The owner insists on a new injector because he is convinced, as was the case last time, that the problem lies with it.
I'm doing another log analysis, and I find the quantity deviation of over 3mg/H from cylinder 2 quite strange. Especially since it occurs multiple times in the range of 1400-1500 revolutions.
The temperature was 74°C, which I unfortunately forgot to record.
LOG-01-IDE04021_&6.xlsx
 File name:  LOG-01-IDE04021_&6.xlsx
 File size:  28.3 KB
 Downloaded:  276 times
Translated on 20-09-2026, 22:02.
Post20-11-2021, 21:57    Subject: CFFB Shakes in Cold Weather Quote
Please remember that positive LLR values indicate that too little fuel is being injected.
So, cylinder 2 is delivering too little, and cylinder 3 is delivering too much.
What is the cause of the reduced output from cylinder 2 or the "misfire" in cylinder 3? That's a good question. What's noticeable is that it only occurs within a specific RPM range in the logs.
Are the connectors/cables on the injectors securely attached and undamaged?
Can the behavior be reproduced by bringing the engine to the specified RPM range? Perhaps someone could observe the engine while it's running to see if anything is vibrating or rubbing.
If the customer absolutely wants the injector replaced, then go ahead and do it. icon_smile.gif If it wasn't the injector, then he'll just have paid for nothing. }
Translated on 20-09-2026, 22:04.
Post21-11-2021, 12:06    Subject: CFFB Shakes in Cold Weather Quote
If the customer absolutely wants the injector replacement, just do it.
If it wasn't the injector, then he just paid for nothing.} Exactly.
While I don't want to start a fundamental discussion about fuel injection quantity correction, measurements taken with the accelerator pedal pressed or moving are meaningless and the resulting numbers are random.
The correction function only works intentionally when the engine is regulated to a constant speed, i.e., in idle mode. If the accelerator pedal is in a different position, the desired torque (fuel injection amount) is regulated. However, there is no adjustment for a constant torque in this case. This would only be possible if the engine control unit (ECU) regularly injected specific amounts of fuel and determined the corresponding correction values. This is similar to how the shift time corrections (rail pressure calibration) are determined in boost mode. However, to my knowledge, this does not exist, but I am happy to be enlightened.
The only notable thing is that cylinder two is the only one showing positive values during the rail pressure calibration.
Translated on 20-09-2026, 22:07.
Herbert likes this.
Post21-11-2021, 13:34    Subject: CFFB Shakes in Cold Weather Quote
Hello Herbert,
In electronically controlled diesel engines (EDC) with a distributor injection pump, the upper speed limit of the low-load range (LLR) was limited by the inertia of the quantity control ring in the electronic control unit (ECU). Because each cylinder required its own specific position, a physical limitation arose at this point due to the control loop.
This does not apply to PD and CR systems. In general, the EDC (Electronic Diesel Control) can modify the injection timing at almost any point.
At least with EDC17, there are speed and quantity ranges within which the LLR (Low-Pressure Fuel Rail) is active. First, let's consider the engine's idle state.
However, since the parameters are freely adjustable, I can't tell you offhand at what engine speed and fuel injection volume the quantity compensation no longer takes place.
I could look up the information in a corresponding dataset for an engine control unit, but then it would be late afternoon. icon_smile.gif
I think it will be somewhere below 2000 rpm.
Translated on 20-09-2026, 22:09.
Post21-11-2021, 19:36    Subject: CFFB Shakes in Cold Weather Quote
Hi Rainer,
It would be interesting to know on what basis an EDC (Electronic Diesel Control) determines the optimal setting beyond the idle state. In idle, the control system operates dynamically. However, in normal operation and beyond, in addition to the motor's torque, there are several external parameters that are difficult or impossible to control, even with a closed-loop control system. Perhaps the system calculates the optimal setting based on the last known idle values? In contrast, the injector quantity adjustment and the zero-quantity correction seem straightforward.
Translated on 20-09-2026, 22:11.
Post02-12-2021, 22:20    Subject: CFFB Shakes in Cold Weather Quote
Translated on 20-09-2026, 22:12.
3bAFN
Post06-12-2021, 21:49    Subject: CFFB Shakes in Cold Weather Quote
The vehicle has been running smoothly for over a week now.
The injector on cylinder 2 was replaced with a new one from Bosch. The injector from the first cylinder was ultrasonically cleaned, as it had to be removed anyway to replace the seals.
No new posts Golf 1J: Gear Shift Problems in Cold Weather Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran shudders/vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vacuum in Cold Conditions Diesel Engine Technology
No new posts 1.9 TDI PD: Cold Start Problems & Solutions Diesel Engine Technology
No new posts ARL Noises: Troubleshooting Cold Start Issues Diesel Engine Technology
No new posts Battery Performance: Cold Weather Affects Charging Speed Diesel Engine Technology
