Stecker neben Batteriepol - Funktion? | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1349 / -0   Thank you, like it!
dieselschrauber likes this.
Post03-03-2022, 20:49    Subject: Quote
Hi Steffen,
While you can't completely disable the start/stop function, you can adjust its behavior, for example, to "Memory." In this mode, the control unit remembers the last setting. This works on my A4 and on our Golf 7. There are several entries on this topic here.
Battery management has its own peculiarities. For example, in the Golf 7, after starting the engine, the battery continues to be drained by various electrical components for several minutes. Most likely, this is part of the testing cycle (it's about extracting performance from the battery, not the motor).
The generator is only stressed when it's under a significant load. Now I have to teach my co-pilot to immediately turn on the seat heaters, fan, air conditioning, lights, and rear window so that the battery charges quickly... icon_rolleyes.gif.
Things get interesting when it comes to auxiliary heaters, especially if they were added later. If it's not installed correctly into the vehicle's electrical system, it can drain the battery, especially on short trips.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust gas recirculation: function and problem areas Technical Articles
No new posts **Hydrostößel: Construction and Function** **Construct... Technical Articles
No new posts OBD2 Connector: Types, Uses & Benefits Diesel Engine Technology
No new posts OBD Connector Problems: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Connectors: Find Suppliers & Buy Online Diesel Engine Technology
No new posts 2. K-line at the connector On-Board Diagnostics (OBD)
