Adabei
08-08-2022, 21:34 Subject: Engine Power Loss After Head Replacement |
A new cylinder head was installed in my BMP 2.0 TDI PD, and the timing of the camshaft was adjusted by rotating it 180 degrees (previously it was 225 degrees).
Since then, I've experienced a loss of power in the lower RPM range, specifically between 1400 and 1800 RPM.
Before, the mail would start moving at 1400 rpm, but now it's completely stopped.
The car shifts into a higher gear later (only from 2300 rpm). Once the next higher gear is engaged, the engine speed drops to 1800 rpm.
So, nothing really happens between the years 1400 and 1800.
The AGR and AGR coolers, as well as the turbocharger, were replaced. The turbocharger's pressure side was checked for leaks, and the N75 valve was replaced.
Does anyone have any idea why there's a loss of power at 1400-1800 rpm?
Translated on 19-09-2026, 22:59.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
08-08-2022, 21:52 Subject: Engine Power Loss After Head Replacement |
Hi.
Yes, and what is your synchronization angle?
Translated on 19-09-2026, 23:00.
Profile PM WWW Garage |
Adabei
09-08-2022, 13:17 Subject: Engine Power Loss After Head Replacement |
Hi, thanks for the quick reply!
With a cold engine:
Rotation angle at standstill: 0.0 degrees KW. Injection start: 5.9 degrees BTDC.
Idle rotation angle: -2.0 degrees crank angle, injection start: 3.1 degrees before top dead center.
Rotation angle at 2205 revolutions: -2.5 degrees. Power output: 7.1 kW. Start of delivery: 7.1% of operating time.
With a warm engine:
Idle camshaft angle: -2.0 degrees. Fuel injection start: 1.9 degrees before top dead center (BTDC).
Rotation angle at 2050 revolutions: -2.5 degrees. KW (kilowatt), start of feed: 2.8 vOT (volts open circuit).
Rotation angle at 2050 revolutions: -2.0 degrees. KW (kilowatt) power, start of feed: 9.3 volts open-circuit.
At idle, Lambda 2.79, air mass 215 mg/H.
Translated on 19-09-2026, 23:02.
09-08-2022, 20:31 Subject: Engine Power Loss After Head Replacement |
Quote: | | Rotation angle at 2050 revolutions is: -2.5 degrees KW, feed start 2.8 vOT |
nicht gut, verstelle mal das Nockenwellenrad bis Du unter +/- 1°KW bist. Ideally, 0°.
In addition, I would also check the vacuum hoses. You can use the VCDS actuator test to extend and retract the VTG rod, which is a good way to see if it's working properly.
Translated on 19-09-2026, 23:03.
Adabei
09-08-2022, 20:54 Subject: Engine Power Loss After Head Replacement |
Okay, I will. The turbo is new and leak-free, and the vacuum hose also fits.
Am I correct in assuming that a twist angle of -2 degrees favors higher engine speeds?
Does a twist angle of +2 degrees favor motor power in the lower speed range?
Translated on 19-09-2026, 23:04.
09-08-2022, 21:54 Subject: Engine Power Loss After Head Replacement |
Adabei wrote: | Thank you, I will do that. The Turbo is new and leak-free, and the vacuum hose also fits.
And does a twist angle of +2 degrees favor motor power in the lower speed range? |
Probably
Translated on 19-09-2026, 23:05.
