Delete Errors Individually: A Step-by-Step Guide
habmichlieb
Post30-08-2022, 15:50    Subject: Delete Errors Individually: A Step-by-Step Guide Quote
I've had my Microcan VCDS for almost 10 years, and today I'd like to know why I can't clear multiple errors at once. After removing the A-panel from my Passat and turning on the ignition, several errors appeared. I had to clear each one individually.
When I try to clear all errors at once, I get this message in VCDS.
"A professional interface is required for this function!"
It surely can't be the case that such a "simple" function is not included in a diagnostic system that cost (at the time) 260 euros.
Is this a matter of personal preference, a bug, or is it actually intended to work this way?
Translated on 14-09-2026, 1:58.
Post30-08-2022, 17:30    Subject: Delete Errors Individually: A Step-by-Step Guide Quote
This function is not working because you opted for a hobbyist version of the diagnostic systems 10 years ago.
The hobby version is intended for hobby use and not for workshop operations. That's why it was about a hundred euros cheaper. icon_idea.gif
Translated on 14-09-2026, 1:59.
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts SEO: Best Practices for Website Optimization Diesel Engine Technology
No new posts Errors cleared after disconnecting the battery On-Board Diagnostics (OBD)
No new posts VP44: Which electrical faults are detected via diagnosis Diesel Engine Technology
No new posts Buy Battery Terminals - Single Pieces Diesel Engine Technology
