matthiasTDI96 Profi-Schrauber
16-05-2013, 12:23 Subject: |
Clean it thoroughly first, unless it's already leaking, in which case you should follow the advice of the previous speaker.
Translated on 17-07-2026, 2:22.
G0dl1k3x
2006 Volkswagen Golf  Free account, no CAN development support
17-05-2013, 12:51 Subject: |
The engine has been cleaned; I'll drive it for a week and then see how it goes.
What is the likelihood that the leak will affect performance? Perhaps the tandem pump isn't providing enough pressure after all?
Profile PM Garage |
RedR32 Schrauber
Joined: 12/21/2008 Posts: 1071 Karma: +11 / -0 Location: Bad Lobenstein 1998 Volkswagen Golf Premium Support
17-05-2013, 17:58 Subject: |
Due to the high pressure and flow rate, there is little influence. 2010 Caddy kombi life 103 tdisg6 BMM KXW
reflexsilber met.
Translated on 17-07-2026, 2:23.
Profile PM Garage |
G0dl1k3x
05-06-2013, 6:17 Subject: |
What I've just noticed while reading through the thread is that I forgot to mention that my MFA (Multi-Factor Authentication) shows about 20% more consumption than the actual value.
I was able to reduce it by 15% using VCDS through adaptation.
Okay, please provide the German text you want me to translate into English. I will only give you the translation.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
05-06-2013, 7:43 Subject: |
Have you also checked whether the fuel temperature measured by the control unit is plausible?
Translated on 17-07-2026, 2:24.
Profile PM WWW Garage |
G0dl1k3x
06-06-2013, 5:51 Subject: |
Can I check it on Saturday morning, when the engine has cooled down?
However, yesterday, when the system was running, the temperature reached 76°C.
VCDS indicates a target value of "approximately ambient temperature," which likely refers to the temperature when the engine is cold.
Translated on 17-07-2026, 2:25.
Profile PM Garage |
06-06-2013, 9:16 Subject: |
Quote: | | Aber im Betriebswarmen Zustand waren es gestern 76°C. |
"That's unfortunate, but it seems plausible. If the temperature had been -10°C, that would explain a lot, as the density of cold fuel is significantly higher. The engine control unit adjusts the fuel injection volume based on fuel density by measuring the fuel temperature."
G0dl1k3x
06-06-2013, 10:58 Subject: |
dieselschrauber wrote: | Quote: | | Aber im Betriebswarmen Zustand waren es gestern 76°C. |
"Too bad, that's plausible. If it were -10°C, that would explain a lot, as the density of cold fuel is significantly higher. The engine control unit corrects the injection amount based on the fuel density by measuring the fuel temperature. | "
It would have been too easy if the error had been found now  .
Yesterday, I happened to have a Touran with the BMM engine in my possession for coding purposes.
I took the opportunity to check the throttle valve angle (MWB 4) at idle, and it's at -2.5 degrees, just like mine.
The driver said that it's running and pulling normally (It could be anything now, unfortunately I couldn't do a test drive  ).
Translated on 17-07-2026, 2:27.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Düsseldorf
dieselschrauber likes this. |
06-06-2013, 11:15 Subject: |
Quote: | At the same time, the camshaft is inspected, as well as the blind plugs of the rocker arm shafts.
Ich berichte dann, kann wieder etwas dauern. |
Have you checked that in the meantime? LG, Onkel BM
Translated on 17-07-2026, 2:28.
G0dl1k3x
06-06-2013, 11:29 Subject: |
Not yet, I don't do everything myself on the car  .
Profile PM Garage |
09-10-2022, 16:03 Subject: |
Yes, same problem.
/newuser.php
