Phaeton GP3 ADR Emergency Shut-off Switch (F317) Test Instructions
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
D1_GP3
Post03-03-2023, 11:07    Subject: Phaeton GP3 ADR Emergency Shut-off Switch (F317) Test Instructions Quote
Hello everyone in the forum community,
My 2010 Phaeton is currently in the workshop (Bosch service) due to a faulty ACC (Adaptive Cruise Control) system. The diagnosis so far indicates that the ADR release switch in the brake booster is defective. Unfortunately, this switch is not available as a separate part, so the entire brake booster needs to be replaced. The workshop doesn't have a testing procedure for the switch, but they would like to test the switch first to rule out other defects before replacing it.
Can anyone in this forum help me with a testing procedure for this component?
Thank you very much and best regards!
No new posts Phaeton Repair: 3D2 Seat Wiring Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Magnet Coil BKV: Error Code 00812 Troubleshooting On-Board Diagnostics (OBD)
No new posts Phaeton Suspension Problems: Common Issues & Fixes On-Board Diagnostics (OBD)
No new posts VW Phaeton 3.0 TDI Engine: CARA Code Details Diesel Engine Technology
No new posts Looking for data for PTC auxiliary heaters from the VW Ph... Transmission, Chassis, Body & Interior
