T3 Engine Swap: Which One Is Right?
Wurstblinker
Post12-11-2003, 11:02    Subject: T3 Engine Swap: Which One Is Right? Quote
Hello fellow diesel mechanics!
As expected, the 1.6 TD (JX) engine in my parents' T3 gave up after 160,000 km!
Some people say it lasts longer or shorter, but regardless, a replacement engine is now needed. Unfortunately, converting to a TDI isn't an option due to the cost, although an AFN engine with its extended gearbox would be a great thing to have. But €6000 is quite a lot!
At Tornau Motoren in Oldenburg (www.motorersatzteile.de), a replacement engine costs €1020. The cylinder head is even new and manufactured in Germany. The engine comes with a one-year warranty without mileage restrictions.
All the attachments will be carried over from the old one, such as the ESP and turbo, etc.
A VW replacement engine costs more than double the price, approximately €2200. It comes with a two-year warranty. Many workshops swear by original VW engines because they are much better rebuilt, meaning they are practically brand new. However, with cheaper options, you never really know what parts have been replaced and what hasn't. (We once had a Mayer ATM 1.6D engine with 50 horsepower that only lasted about 60,000 km before it failed.)
'Furthermore, I still don't understand the difference between 'partially refurbished' and 'fully refurbished'.'
I would like to thank you in advance for any information and tips you can provide.
Sausage blinkers.
Translated on 28-07-2026, 16:56.
Ingo
Post12-11-2003, 16:23    Subject: T3 Engine Swap: Which One Is Right? Quote
As far as I know, you only get a 2-year warranty on the VW ATM if you have it installed by them. You're probably aware that this isn't exactly cheap.
I would convert it to a 1.9 TDI engine, even though it might cost more.
Translated on 28-07-2026, 16:59.
Post12-11-2003, 19:06    Subject: T3 Engine Swap: Which One Is Right? Quote
Okay, if you're already planning to replace the engine anyway, I would also look into getting an AFN engine. That will make the van a lot more fun to drive. However, it will probably break your gearbox next. But honestly, isn't €6000 too much? For that price, you're basically buying a running T4.
Otherwise, I'd suggest checking out the online auction site. You can find original T3 machines there at a relatively low price, but without any warranty! However, how long do you actually plan to keep driving the T3? If you can get a year of warranty for around €1000 from Oldenburg, then it might be worth it! It doesn't seem like a bad deal.
Translated on 28-07-2026, 17:00.
Wurstblinker
Post12-11-2003, 20:38    Subject: T3 Engine Swap: Which One Is Right? Quote
'So, in Neumünster, someone is asking for around €3800 to convert a 1-liter engine. For an AFN (engine), it would cost €450-€500 more. However, that doesn't include extending the lifespan of the gearbox. And 240 Nm on a gearbox only designed for 170 Nm? I wonder if that's really optimal. Also, the engine will then always rev so high, and you wouldn't get any fuel economy benefits.'
A new JX costs €1700.
It's definitely worth considering, as it's a very beautiful Atlantic! ( http://pic.autoscout24.com/images/3/8/3/21774383_1.jpg )
'MFG' stands for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English. It is a common way to end a formal letter or email.
Translated on 28-07-2026, 17:01.
t3_tdi
Post12-11-2003, 21:26    Subject: AAZ: What is AAZ? Meaning & Definition Quote
Hi there,
'I think the AAZ (1.9L) engine with parts from the JX could be a good alternative. I don't have any personal experience with it myself, but I often hear that this conversion is relatively easy to do and should be fun in a T3.'
The AAZ conversion is cheaper and less complex compared to the 1Z/AHU or AFN engines. Perhaps you should do some research in that direction as well...
Best regards, Gunnar.
Translated on 28-07-2026, 17:03.
No new posts Austauschmotor für VW mit MKB 1Z Diesel Engine Technology
No new posts Austauschmotor und Motorsteuergerät Diesel Engine Technology
No new posts Motorschaden - Austauschmotor - Chip ? Diesel Engine Technology
No new posts AWX Piston Damage: AVF Engine Replacement On-Board Diagnostics (OBD)
