Steering wheel trim A4 8K
Post21-03-2023, 15:44    Subject: Steering wheel trim A4 8K Quote
Are these rubber-metal bushings on the guide rods at the rear of the front axle, connecting to the body (are they broken/defective according to TÜV standards)?
Both show cracks running around the entire rubber surface.
If so, is it worth replacing the bushings with that mileage (170,000 km), or should I just replace the entire steering rack?
For the ball joint separator, Audi uses the part number T40010A. It's available at a high price as the Hazet 1790-4, and slightly cheaper as the Kukko 129-3-A. Does anyone know of a good, high-quality alternative?
 File size:  4.11 MB
 Viewed:  478 times
 File size:  3.57 MB
 Viewed:  435 times
 File size:  4 MB
 Viewed:  547 times
Translated on 05-07-2026, 15:11.
Karma: +645 / -0   Thank you, like it!
dieselschrauber likes this.
Post21-03-2023, 17:01    Subject: Steering wheel trim A4 8K Quote
Is this photo taken when the device is powered on or off?
Does noticeable play exist, and if so, does the car feel unstable or "floaty"?
Translated on 05-07-2026, 15:12.
Post21-03-2023, 18:27    Subject: Steering wheel trim A4 8K Quote
The vehicle is on its wheels. No complaints regarding the driving.
Translated on 05-07-2026, 15:13.
Post21-03-2023, 19:28    Subject: Steering wheel trim A4 8K Quote
To be honest, with such minimal cracking and no impact on handling, I wouldn't do anything... new handlebars are more likely to break.
Post21-03-2023, 20:14    Subject: Steering wheel trim A4 8K Quote
The question is, what the people in the pit lane are saying. Because I have to go through there. The cracks are already more than 1mm deep and extend beyond the surface.
Post21-03-2023, 20:20    Subject: Steering wheel trim A4 8K Quote
My Dekra inspector has a lenient approach, so it would probably pass.
Translated on 05-07-2026, 15:14.
Post21-03-2023, 21:09    Subject: Steering wheel trim A4 8K Quote
Go back to Go.
If so, is it worth replacing the bushings with a mileage of 170,000 km, or should I just replace the entire steering column?
For the ball joint separator, Audi uses the part number T40010A. It's available at a high price as the Hazet 1790-4, and slightly cheaper as the Kukko 129-3-A. Does anyone know of a high-quality alternative?
Translated on 05-07-2026, 15:15.
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
dieselschrauber and Herbert likes this.
Post22-03-2023, 14:16    Subject: Steering wheel trim A4 8K Quote
For the ball joint, Audi calls the extractor T40010A. It's available at a high price as the Hazet 1790-4, and slightly cheaper as the Kukko 129-3-A. Does anyone know of a high-quality alternative?
I use some specialized tools, such as pullers and extractors, from brands like BGS, SW-Stahl, and TengTools.
For me, the quality is comparable to Hazet!
If these manufacturers have the product I'm looking for and the price is right, I would buy it without hesitation!
At relevant trade shows (Automechanika, Essen Motor Show, etc.), you can often find discounted (hand) tools, including Hazet icon_wink.gif, thanks to special offers.
Best regards, Richard.
Polo V 1,6 Tdi (CAY)
Translated on 05-07-2026, 15:17.
No new posts Tie Rods: Steering Linkages & Components Transmission, Chassis, Body & Interior
