{INJECTION TIME DEVIATION} 1.6 TDI Golf 7
sardu
Karma: +0 / -1   Thank you, like it!
Post27-03-2023, 19:19    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
My car is jerking when stationary and consuming more fuel than usual. I suspect a faulty injector. There are no fault codes in the memory, but I have read out the following measurements. Does this mean that the injector for cylinder 4 is faulty?
Injection timing deviation cylinder 1 -8 µs
Injection timing deviation cylinder 2 -6 to -13 µs fluctuating
Injection timing deviation cylinder 3 3 µs
Injection timing deviation cylinder 4 19 µs
chli1976
Post27-03-2023, 19:39    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
It needs to include the measurement value for injection quantity deviation or something similar, which are displayed in mg/stroke, please post those.
VCDS
sardu
Post27-03-2023, 19:51    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
I found this, but I can't find any information about fuel injection volume differences per cylinder… It seems like it's not available. I have also put everything together in a video: [Videos can be uploaded here!]
IDEO... Average Injection Volume
IDEO... Main Injection: Target Value
IDE1
Injection 2: Target Quantity
IDE1... Injection 1: Target Value
IDE1... Direct Injection 3: Target Quantity
5 mg/stroke
2.93 mg/stroke
0.00 mg/stroke
0.00 mg/stroke
0.00 mg/stroke
Post27-03-2023, 20:33    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
Please upload your video in this topic to avoid link leaching. icon_idea.gif
dieselschrauber likes this.
Post27-03-2023, 22:07    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
chli1976 wrote:
It needs to show the measurement value for injection quantity deviation or something similar, which are displayed in mg/stroke, please post those
Refers to the 1.6 TDI gear shift timing adjustment.
sardu
Post31-03-2023, 17:31    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
Unfortunately, I was unable to find any extended measurement values in the vcds data. Do you have another idea?
pic-67669617164270ac2f085f-a74bBm
 File size:  8.39 KB
 Viewed:  429 times
Post31-03-2023, 17:50    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
I'm unfortunately unable to open the image.
You need to relate the injection duration, the average injection amount, and the injection timing deviations from your first post to each other, then you will have the injection amount deviation per cylinder.
The 1.6 TDI STG only provides information about injection timing deviations, not quantity correction values (I mistakenly wrote "shift time correction" above).
The injection duration is around 100 µs at idle for my 2.0 TDI. That would be acceptable for these deviations in my engine.
sardu
Post31-03-2023, 18:15    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
Ok, then the only option is to go to the workshop.
Post31-03-2023, 19:19    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
Why no diagnosis, no check of timing, no check of return flow?
The workshop would initially only be limited and not applicable for certain tasks, for example, for checking the compression.
sardu
Post31-03-2023, 19:50    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
I am not a kfzler, so I will initially focus on VCDS diagnostics. Tax periods would be excluded as they are only temporary and then also okay again.
Post31-03-2023, 21:43    Subject: {INJECTION TIME DEVIATION} 1.6 TDI Golf 7 Quote
Time for an auto-scan ...
No new posts Golf TDI Manual: Specs, Review & More Diesel Engine Technology
No new posts VW Golf 4 AHF: Starting Problems & Solutions Diesel Engine Technology
No new posts Golf TDI Engine Noise: Causes & Fixes Diesel Engine Technology
No new posts Golf 3 Door Frozen: Repair & Solutions Transmission, Chassis, Body & Interior
