DPF Error: Volkswagen Golf 6 2.0 TDI Fix
Chris02
Post02-04-2023, 17:01    Subject: DPF Error: Volkswagen Golf 6 2.0 TDI Fix Quote
Hello everyone,
I hope you can support me.
Der Golf 6 meiner Schwester war im Notlauf. Darauf hin habe ich den Fehlerspeicher ausgelesen und gelöscht. Log, below.
Since then, the car has been running without any problems. However, I would have expected a high soot value in the error memory, which is not the case. The car is almost exclusively driven on short trips and often doesn't get properly warm. That's exactly what you shouldn't do with a diesel engine, I know icon_wink.gif.
I wanted to try a regeneration process while the system was idle, but it's being interrupted with the following error:
"Interrupted (security error) | Error".
Can you identify the cause of the error in the log? The DPF shouldn't be clogged. Should I just continue driving?
Thank you very much and best regards.
Chris.
8194 - Diesel particulate filter.
P2458 00 [237] - Regeneration time.
Warning light ON - confirmed - checked since last reset.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1.
Mileage: 122,869 km
Date: 2023.03.31
Time: 18:54:24
Motor speed: 2362.00 rpm.
Normalized load value: 53.3%
Vehicle speed: 92 km/h
Coolant temperature: 80 °C.
Intake air temperature: 15 °C
Atmospheric pressure: 950 millibars.
Voltage at terminal 30: 14,700 V.
Lost learning counter via OBD: 40.
Particle filter regeneration time counter: 12600.10 s.
Particle filter: Kilometers since last regeneration: 394428 km.
Particulate filter: Soot mass measured: -4.25 g.
Particle filter: Calculated soot mass: 6.36 g.
Particle filter differential pressure dynamic offset: 5 hPa
Translated on 23-07-2026, 21:25.
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
dieselschrauber and Chris02 likes this.
Post02-04-2023, 17:43    Subject: DPF Error: Volkswagen Golf 6 2.0 TDI Fix Quote
Hello Chris,
With a car scan, the answer would be somewhat simpler.
It is possible that the regeneration process could not be completed within the required time due to the short distance.
If you don't have any other error entries, you could check the exhaust temperature sensor and differential pressure sensor for plausibility.
Otherwise, next time please use the Autoscan feature.
Michael.
Translated on 23-07-2026, 21:30.
Chris02
Post02-04-2023, 20:54    Subject: DPF Error: Volkswagen Golf 6 2.0 TDI Fix Quote
Hello Michael,
Thank you for your response.
The auto-scan showed no issues. There was only one problem detected: an issue with the rain sensor; otherwise, there were no other entries.
Chris.
Translated on 23-07-2026, 21:31.
dieselschrauber likes this.
Post04-04-2023, 10:08    Subject: DPF Error: Volkswagen Golf 6 2.0 TDI Fix Quote
For further assistance, please post an Autoscan. This will allow us to check if you have a suitable VCDS license. If you do, we can provide help. If not, unfortunately, we cannot assist you further here.
Translated on 23-07-2026, 21:32.
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J MJ 2001, Fehler 01435 im ABS-STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intermittent error code P0234 on a Passat 3C 2.0 TDI Diesel Engine Technology
No new posts Golf 5 2.0 TDI Engine Oil: 170HP Performance Diesel Engine Technology
No new posts Golf 7 2.0 TDI - Hesitation/Misfire at Partial Load Diesel Engine Technology
No new posts Golf 2.0 TDI 110hp - boost pressure too high at partial load Diesel Engine Technology
