Octavia 1.6 Cayc Nails
chriskross
Post20-07-2016, 10:19    Subject: Octavia 1.6 Cayc Nails Quote
Hello!
"I'm experiencing a problem with my Octavia 1Z 1.6CR CAYC engine: it makes a noticeable knocking sound at low RPMs. It's most audible after shifting gears, when accelerating between 1200-1500 RPM."
There's no noticeable stuttering or loss of power, it's just the rattling that bothers me.
Skoda informed me that the injectors are faulty. I performed a fuel return flow measurement, and all four injectors showed the same amount of fuel being returned.
The values for the idle speed control would be:
1 cylinder, +2 mg.
2 cylinders -0.5
3 cylinders -0.86
4 cylinders + 1 mg.
The first cylinder is out of sync.
I believe the current software version is: 9972.
Address 01: Engine Control Module (J623-CAYC)
Label file: DRV\03L-906-023-CAY.clb
Part number SW: 03L 906 023 AG, Part number HW: 03L 906 023 AG.
Component: 1.6L R4 CR turbo diesel H23 9972.
Revision: --H23--- Serial Number:
Encoding: 00114016032400080000
Operating number: WSC 38940 001 1048576
ASAM Dataset: EV_ECM16TDI02103L906023AG 003011
ROD: EV_ECM16TDI02103L906023A_VW32.rod
VCID: 6BD1975582AA6C66BB-803E
Does anyone have more experience with the injectors?
A6 AFB
A6 BRE DPF
Translated on 16-07-2026, 15:29.
alevuz
Karma: +32 / -0   Thank you, like it!
Post20-07-2016, 11:55    Subject: Octavia 1.6 Cayc Nails Quote
Hello...
Could it be that one of the injectors is failing and performing even worse than indicated? Shouldn't the long-term fuel trim (LTFT) value be close to zero, rather than 1.64 like you have?
Or is it just the usual problem with the 1.6 injectors again...?
Does it start normally?
Sure, here's the translation:
"SG" can have different meanings depending on the context. It could stand for "Spielgemeinschaft," which is a German term for a sports club or association that combines players from multiple teams or organizations. Alternatively, it could refer to "Säkularkantor," a type of church musician who does not hold religious beliefs. Finally, "SG" might be an abbreviation for "Sonstige," meaning "other" or "miscellaneous."
Touareg V10 TDI (AYH)
Translated on 16-07-2026, 15:33.
Post20-07-2016, 15:19    Subject: Octavia 1.6 Cayc Nails Quote
1 cylinder, +2 mg.
2 cylinders -0.5.
3 Cyl -0.86
4 cylinders + 1 mg
The sum of all offset values always results in zero. Simply take a Screenshot in VCDS or click the "Save" button in the program.
Translated on 16-07-2026, 15:34.
chriskross
Post20-07-2016, 17:02    Subject: Octavia 1.6 Cayc Nails Quote
Attached is the image.
 File size:  257.34 KB
 Viewed:  4158 times
 Viewed:  2215 times
A6 AFB
A6 BRE DPF
Translated on 16-07-2026, 15:35.
Post20-07-2016, 17:21    Subject: Octavia 1.6 Cayc Nails Quote
It results in a sum of 0.00 mg/H. Consequently, the initially reported values were not actually correct.
The values are within the acceptable range. Regarding the noise levels, there were indeed software updates for the 1.6 TDI engines, but your software version appears to be quite up-to-date.
What exactly is the problem, and is there an audio file of the hammering sound?
Translated on 16-07-2026, 15:36.
chriskross
Post20-07-2016, 19:59    Subject: Octavia 1.6 Cayc Nails Quote
dieselschrauber wrote:
It results in a sum of 0.00 mg/H. Consequently, the initially posted values were not actually correct.
Best regards, Rainer
The engine control unit (ECU) has been updated to the latest software version, and then a small-batch adaptation process will be performed. According to the diagnostic tool ODIS, all injectors are outside of their specified operating range.
I will upload the audio file soon.
Best regards.
Chris.
A6 AFB
A6 BRE DPF
Translated on 16-07-2026, 15:37.
chli1976
Post20-07-2016, 20:57    Subject: Octavia 1.6 Cayc Nails Quote
Normally, there's a policy of goodwill where defective ODIS units should be replaced.
VCDS
Translated on 16-07-2026, 15:38.
Post20-07-2016, 21:20    Subject: Octavia 1.6 Cayc Nails Quote
What are the injector timing values?
Background:
Translated on 16-07-2026, 15:39.
chriskross
Post23-07-2016, 16:55    Subject: Octavia 1.6 Cayc Nails Quote
Hi.
I can't find the injection timing data (multi-point working behavior).
Do you know which ones those are for the PCR 2.1?
Are these piezoelectric injectors?
A6 AFB
A6 BRE DPF
chli1976
Post23-07-2016, 18:07    Subject: Octavia 1.6 Cayc Nails Quote
I think you can skip that, because there are no reference values available.
VCDS
Translated on 16-07-2026, 15:40.
Post24-07-2016, 10:36    Subject: Octavia 1.6 Cayc Nails Quote
chli1976 wrote:
I think you can skip that, because there are no reference values.
But perhaps there are comparable values available for CAYC engines that don't exhibit the same knocking issue?
If he doesn't look, there will never be any, icon_cool.gif.
Martininii
Karma: +24 / -1   Thank you, like it!
Post16-04-2023, 20:48    Subject: Nailing Quote
It's an old thread, but I have a question about it, since my family owns the same engine.
Does the knocking sound caused by faulty injectors on this engine always only occur in the lower RPM range, or also in the higher RPM range?
As I understand it, you can't always rely solely on the measured values, such as return flow measurements and data from VCDS. I also lack the experience in this area.
Caddy 3 mit BLS Motor, 105PS, DPF (0603/AGB)
Renault Laguna 2 mit F9Q Motor, 107PS/120PS (3004/158)
Translated on 16-07-2026, 15:41.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Golf IV / Octavia 1 Water ingress at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts BLS: Nail Stability at Partial Load Diesel Engine Technology
No new posts A6 2.5 TDI: Misfire & Rough Idle Diesel Engine Technology
No new posts TDI Engine: Nail/Knock Repair Guide Diesel Engine Technology
No new posts Low Power/Torque, Poor AFR: Troubleshooting Guide Diesel Engine Technology
