bindpe Blaumann
Joined: 08/25/2006 Posts: 203 Karma: +5 / -2 Location: ingolstadt
07-05-2023, 14:26 Subject: TDI AHU: Turbo Oil Return Line Replacement |
Hello.
My Golf 3 TDI with the AHU engine has never let me down in the last 400,000 km, and I want to keep it that way. All the hoses and lines are still original, so I figured it's time to replace them.
Regarding the TL (presumably a specific vehicle or component), I wanted to replace the oil return and supply lines. Is it possible to do this with the component still installed?
Does anyone have any tips for me on the best way to do this without stripping any screws?
Thank you. Golf III TDI AHU 402Tkm
Translated on 25-09-2026, 7:22.
Herbert Profi-Schrauber
dieselschrauber likes this. |
07-05-2023, 15:36 Subject: TDI AHU: Turbo Oil Return Line Replacement |
Quote: | All the hoses and pipes are still original, and I wanted to finally get around to replacing them.
At the TL, I wanted to replace the oil return and supply lines,.... |
"Why? Are the pipes rusted?"
Herbert. Horch A4 8K CJCD
Translated on 25-09-2026, 7:23.
bindpe Blaumann
07-05-2023, 17:50 Subject: SEO: Best German to English Translation Services |
Not yet.
But the return line doesn't look very reliable anymore.
I also sometimes drive 600 km non-stop in this car, and I don't want to be stranded on the side of the road. I simply want to continue to have the maximum reliability.
I guess if it broke, it was probably due to the turbo.
vg Golf III TDI AHU 402Tkm
Translated on 25-09-2026, 7:24.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
07-05-2023, 18:00 Subject: SEO: Best SEO Agency | Top SEO Services |
bindpe wrote: | not yet.
I also sometimes drive 600 km non-stop in this car, and I don't want to get stranded on the road. I simply want to continue to have the maximum reliability.
vg |
Hi.
If the line were to "tear," the mechanical stress wouldn't be your biggest concern.
If it looks very worn out, you will eventually lose engine oil from it.
Translated on 25-09-2026, 7:26.
Profile PM WWW Garage |
bindpe Blaumann
07-05-2023, 19:04 Subject: TDI AHU: Turbo Oil Return Line Replacement |
Hello Rainer,
"How do you mean 'in the event of a detachment,' the cable would be your least problem'?" Golf III TDI AHU 402Tkm
Translated on 25-09-2026, 7:27.
Herbert and E30_V8 likes this. |
07-05-2023, 20:21 Subject: TDI AHU: Turbo Oil Return Line Replacement |
bindpe wrote: | Hello Rainer.
How do you mean "in the event of a detachment," the line would be your least problem." |
If the turbocharger is still bolted to the cylinder head, the hose cannot "break off".
bindpe Blaumann
08-05-2023, 6:34 Subject: TDI AHU: Turbo Oil Return Line Replacement |
Okay, don't panic, but it looks like the pipe connections might be coming loose. Golf III TDI AHU 402Tkm
Translated on 25-09-2026, 7:28.
