Speed Limit MAN TGE/Crafter
patmit
Post08-05-2023, 14:46    Subject: Speed Limit MAN TGE/Crafter Quote
Good morning, everyone,
has anyone already had experience with the speed limit on TGE/Crafter?
I am trying to activate a (reversible!) limit. The "IDE02248 - Individually adjustable maximum speed limit" adaptation channel seems plausible.
Currently, the speed in the channel is set to 300km/h. A change would require a login code.
Can anyone help me?
a) confirm that I am in the correct channel here and
b) Name the code?
Thank you.
Patrick
Logs.zip
 Scan MSG
Scan MSG
 File name:  Logs.zip
 File size:  21.64 KB
 Downloaded:  624 times
patmit likes this.
Post08-05-2023, 22:30    Subject: Speed Limit MAN TGE/Crafter Quote
Caution. All the HGB (German-language) tax calculators I am familiar with can only be adjusted downwards.
So from 300 km/h to 80 km/h. But not from 80 km/h to 120 km/h.
Before you do anything, make sure to check!
Best regards, Rainer
patmit
Post10-05-2023, 7:30    Subject: Speed Limit MAN TGE/Crafter Quote
Hello Rainer,
yes, I have unfortunately also come across such information.
There are adjustment channels for both static and individual maximum speed limiting.
I was hoping that someone from the forum could shed some light on this.
At least, according to the MAN workshop, there is a possibility to set a limit that can be reversed.
Since the vehicle is not yet registered, I was hoping for a VCDS solution...
Greetings
Patrick
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Limiter Removal: VW Crafter & MAN TGE Dieselschrauber Bar
No new posts VW Crafter: Van for Sale & More On-Board Diagnostics (OBD)
No new posts Crafter Service: Intervals & Costs On-Board Diagnostics (OBD)
No new posts VW Crafter Tow Hitch Coding Electrical Systems, Vehicle Electronics, Multimedia
