TDI AHU ; 00575 - Saugrohrdruck Regeldifferenz | Posts 32+
Go to page: Previous  1, 2, 3
dieselschrauber likes this.
Post22-06-2023, 15:47    Subject: Quote
Why don't you remove the actuation rod (using a circlip) and unscrew the pressure sensor? Then you can manually check the valve's movement, inspect the pressure sensor, and, if necessary, drain any oil sludge?
Adjust according to RLF guidelines during assembly.
You might damage the membrane with an overpressure of two bar.
Translated on 05-07-2026, 6:03.
bindpe
Karma: +5 / -2   Thank you, like it!
Post23-06-2023, 5:58    Subject: Quote
Good morning, Herbert.
"2 bar is the pressure the can should withstand, which is the normal pressure exerted on the can, right?"
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 05-07-2026, 6:04.
dieselschrauber, Herbert and E30_V8 likes this.
Post23-06-2023, 11:06    Subject: Quote
The membrane activates at approximately 1.6 bar of absolute pressure. This corresponds to only 0.6 bar of gauge pressure (relative pressure). Therefore, heed Herbert's warning: do not exceed a pressure of 2 bar when using the compressor.
The engine is running at a pressure of 1.9 bar absolute, which is equivalent to 0.9 bar above atmospheric pressure. The N75 valve modulates this 0.9 bar overpressure down to 0.6 bar overpressure using atmospheric pressure, and within the range of approximately 0.55 bar to 0.65 bar, it opens or closes the wastegate accordingly.
In addition to manual movement, you can also automate the movement of the rod. To do this, connect the N75 to a pressure regulator with approximately 0.7 bar. Then, connect the control of the N75 to a turn signal bulb and activate the hazard lights. The wastegate will then move back and forth approximately once per second as long as the hazard lights are on and there is still pressure in the system.
Guste.
Translated on 05-07-2026, 6:05.
bindpe
Post24-06-2023, 5:54    Subject: Quote
Hello.
Thank you for the tip about using the hazard lights.
I probably phrased it poorly. I applied a pressure of 2 bar absolute pressure using a pressure regulator, and that seems to have been enough to survive without damaging the container. As I mentioned, the problem is no longer occurring. I will provide further updates.
Spritmonitor.de
Translated on 05-07-2026, 6:07.
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Document: Performance Drop, Error 00575, V6 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document error 00575 with full throttle, AKN and AFB engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Intake Manifold Pressure Differential Regulation Diesel Engine Technology
No new posts Intake Manifold Pressure Problem Solved!:) Diesel Engine Technology
No new posts Intake Manifold Pressure Regulation Difference Upload
No new posts Intake Manifold Pressure: Regulation & Mass Air Flow? On-Board Diagnostics (OBD)
