Fuel gauge and speedometer not working
Rocksound
Post13-11-2003, 17:09    Subject: Fuel gauge and speedometer not working Quote
Hello!
My friend's A4 TDI, manufactured in 2002, had been sitting idle for two weeks. When he drove off yesterday, he noticed that the speedometer, just like the fuel gauge, was no longer working.
What could that be? Can someone help?
Sure, here's the translation:
'Thank you in advance!!!'
Daniel
PrivatBereich
Post13-11-2003, 17:22    Subject: Fuel gauge and speedometer not working Quote
It can be many things!
A few more details would be helpful.
- What has already been checked? (at least the fuse?)
- What else is affected? (especially by those consumers who are connected to the same circuit breaker)
- Is it a permanent error, or a temporary, one-time occurrence?
Without further information, I can offer two (completely unnecessary) tips:
- Fuse
- or a broken cable.
(Incredibly well combined or icon_eek.gif)
-Private
Rocksound
Post13-11-2003, 18:28    Subject: Fuel gauge and speedometer not working Quote
Do you happen to know if the fuel gauge and speedometer are connected to the same fuse?
Golfmann
Post13-11-2003, 19:53    Subject: Fuel gauge and speedometer not working Quote
The light of the instrument cluster is fused together with the instrument lighting and the license plate light (fuse number 3).
Don't think you'll find a fuse for the functions of the combination instrument. However, I'm not entirely sure. I suspect there might be a problem with the connection. Cable break.
Post13-11-2003, 20:00    Subject: Fuel gauge and speedometer not working Quote
There's no separate fuse for it; it's made up of a large circuit board. Connect a VAG Com and see what error codes it throws. But if you don't have a knack for electronics, like I do, then I'm afraid things might go badly for you!
But here's a tip: Once, a cheeky rodent gnawed on my tachometer signal cable... it's worth taking a look! It doesn't explain the fuel gauge because the cables are routed within the car.
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L Remote Control: Troubleshooting & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L: Frequency Display Not Working - Fix? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts OBD to Speedometer Adapter Skoda Octavia 1U (No CAN) On-Board Diagnostics (OBD)
No new posts Speedometer Error: Driving Without a Speedometer? Diesel Engine Technology
No new posts ESP Failure: Causes and Solutions On-Board Diagnostics (OBD)
No new posts ASR Not Working: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
