Encode the second control unit to wfs
Horstel
Post17-10-2005, 19:03    Subject: Encode the second control unit to wfs Quote
Unfortunately, I still haven't found an answer to my question, even after searching the forum.
I want to code a second control unit with a tuning chip for my 1Z engine.
Does the original control unit remain suitable for reinstallation after the new control unit has been programmed, or does it also need to be reprogrammed?
More precisely, can I theoretically use both of them?
Thank you for any potential response.
Horstel.
Post17-10-2005, 19:08    Subject: Encode the second control unit to wfs Quote
The WFS (Warm-Function Specification) is adapted to match the specific engine control unit (ECU).
This process must be repeated every time an engine control unit (ECU) is replaced.
donalexo
Post19-10-2005, 20:45    Subject: Encode the second control unit to wfs Quote
... unless the data states in both MSGs have the same identifier icon_wink.gif.
Touran 1.9 TDI, EZ 09/2004
Post19-10-2005, 21:43    Subject: Encode the second control unit to wfs Quote
Horstel
Post20-10-2005, 7:29    Subject: Encode the second control unit to wfs Quote
Regarding MSGs, they have the same identifier.
Can this be read out from an MSG using VAG-COM, and can the value be changed accordingly?
Or is that hardware?
Horstel.
Rudi
Post20-10-2005, 8:11    Subject: Encode the second control unit to wfs Quote
Identifier and identifier...
It's not just about the part number.
To truly make the STGs interchangeable, one needs to do something.
to tinker with it and reprogram it (which has nothing to do with chip tuning).
VAG-COM doesn't provide any helpful information.
Rudi
Post22-11-2023, 21:27    Subject: Encode the second control unit to wfs Quote
huebi wrote:
Hi everyone.
The data is stored in the flash memory, and that's also where the tuning adjustments are made.
Then there's the EEPROM, which stores the coding, adaptation values, mileage, and data for the immobilizer. In the case of the EDC15 and EDC16 systems, the EEPROM can also be read out and written to the second control unit via the OBDII interface. Then, the simple device replacement, as it worked for me, should function well.
huebi
icon_wink.gif Thank you!
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ECU Coding: VW Sharan 028 906 021 JJ (AFN) On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Automatic Transmission Control Module Coding AFN On-Board Diagnostics (OBD)
No new posts ECU Coding: Where to Find the Code Table? On-Board Diagnostics (OBD)
No new posts Airbag Control Unit: Coding Only? On-Board Diagnostics (OBD)
