Byte 18 again
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Knox88
Post22-08-2023, 9:39    Subject: Byte 18 again Quote
What do I need to code if I want the taillights to light up with the turn signals?
Vehicle: Golf 6 Variant, year of manufacture 2009, halogen headlights (front and rear).
Currently, byte 18 is at 02.
Have I already read byte 18 encoded as 45, but before that, was it encoded as C0 and then as 45?
Can someone like that confirm it?
I have added "Autoscan".
Autoscan Golf 6 Variant -191580km.txt
 Byte 18 again
Byte 18 again
 File name:  Autoscan Golf 6 Variant -191580km.txt
 File size:  10.97 KB
 Downloaded:  897 times
Knox88
Post20-04-2024, 9:09    Subject: Byte 18 again Quote
Does anyone have a plan?
Karma: +1354 / -0   Thank you, like it!
dieselschrauber likes this.
Post20-04-2024, 13:08    Subject: Byte 18 again Quote
Probably no one will respond here because such vehicle-specific and also somewhat exclusive modifications are very individual.
I would look for Golf 6 coding (or modifications) using Gockel, and I'm sure you'll find something. If the adaptation channels are as diverse as they are in the Golf 7, you might also find what you're looking for while searching through them.
Karma: +805 / -0   Thank you, like it!
Post23-04-2024, 20:20    Subject: Byte 18 again Quote
I would first update the VCDS and then check again with the coding assistant. icon_idea.gif
No new posts Sudden performance loss after restart, then okay again Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Identify 30/23 Byte: Board Net & Turn Signal On-Board Diagnostics (OBD)
No new posts Polo 6R: Engine Byte 4 Not Set - Normal? On-Board Diagnostics (OBD)
No new posts GRA in B4: Another Case? Diesel Engine Technology
No new posts LMM: Another Instance? Diesel Engine Technology
