Adjusting VP44 dynamically -> Problems
altonno
Post14-12-2004, 18:42    Subject: Adjusting VP44 dynamically -> Problems Quote
Hello guys,
"Does anyone happen to be familiar with this topic? I was planning to dynamically adjust my fuel injection pump today. I've already obtained the adjustment values (target values). I went into the engine control unit, measurement block 4, and so far everything seemed to be working, but the injection start timing is showing 0°, and adjusting it mechanically doesn't change anything! Could it be that the pump is somehow faulty?" Or maybe it was because I only had a coolant temperature of 62° (unfortunately, I can't get it any higher with this weather).
AL
Post01-09-2024, 14:56    Subject: Adjusting VP44 dynamically -> Problems Quote
Okay, I'm ready. Please provide the German text you want me to translate.
No new posts VE Injection Pump Data: 6-Cylinder Engine Performance (VP44) Technical Data
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Dynamically adjusting the timing belt on a T4 2.5 TDi On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. T4 TDI: Dynamically Adjust Injection Timing with Bosch KT... Diesel Engine Technology
No new posts Dynamically check and, if necessary, adjust the start of ... On-Board Diagnostics (OBD)
No new posts VP44 control unit replacement On-Board Diagnostics (OBD)
