Ford Transit, manufactured in 2016, battery replacement
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1354 / -0   Thank you, like it!
Post18-10-2024, 20:00    Subject: Ford Transit, manufactured in 2016, battery replacement Quote
Hi there,
Does this model require any adjustments to the new battery when replacing it?
Unfortunately, I don't have any more information about the vehicle at the moment (first registration in 2016, diesel engine, double cab with a pickup bed).
Translated on 18-07-2026, 15:42.
Ich_Can_nix
Karma: +253 / -0   Thank you, like it!
dieselschrauber and Herbert likes this.
Post18-10-2024, 23:30    Subject: Ford Transit, manufactured in 2016, battery replacement Quote
Good evening, Herbert.
For Ford vehicles, the battery management system (BMS) needs to be reset after replacing the battery. However, this can often be done without a diagnostic tool on many models.
If you have the exact data, you'll be able to find it using the search term.
Continuing Ford BMS reset.
Otherwise, we would have to write again icon_smile.gif.
Michael.
Translated on 18-07-2026, 15:44.
dieselschrauber likes this.
Post19-10-2024, 7:48    Subject: Ford Transit, manufactured in 2016, battery replacement Quote
Good morning, Michael,
First of all, thank you – under that term, I found a whole selection for Ford models.
I'm still waiting to see if the suspected starter battery is actually the problem, and I plan to replace it myself. If that doesn't work, we'll try the sequence for the "Nugget" first.
Translated on 18-07-2026, 15:45.
Post20-10-2024, 16:36    Subject: Ford Transit, manufactured in 2016, battery replacement Quote
Hi there,
It seems the battery issue has been resolved. When someone tried to start the car in my presence, the starter motor ran briefly and then stopped.
Translated on 18-07-2026, 15:46.
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Ford Fiesta Temperature Sensor: Problems & Fixes General Tips
No new posts Ford Transit: No glow plugs? Troubleshooting. Diesel Engine Technology
No new posts Ford Transit: Power Loss at Operating Temperature Diesel Engine Technology
No new posts Ford Transit / Lucas DSA947 goes into limp mode under load On-Board Diagnostics (OBD)
No new posts Power Windows Limited After Battery Change On-Board Diagnostics (OBD)
