T5 CAAD ash value accidentally set to 0
Jo_T5
Post28-10-2024, 16:29    Subject: T5 CAAD ash value accidentally set to 0 Quote
Hello colleagues,
I was troubleshooting the aforementioned issue. Accidentally set the ash values of the DPF to 0 in the basic settings of the T5.
If I try to increase the mileage in the adjustment channels now, the program requires access permission.
How can I correct it?
Thank you and best regards, Jo.
T5 mit CAAD Maschine
4B mit AVF Maschine
Jo_T5
Post28-10-2024, 17:07    Subject: T5 CAAD ash value accidentally set to 0 Quote
I was able to fix it again by enabling the customization option!
4B mit AVF Maschine
Karma: +1344 / -0   Thank you, like it!
dieselschrauber and Turbinchen likes this.
Post28-10-2024, 17:11    Subject: T5 CAAD ash value accidentally set to 0 Quote
VCDS will show you a tooltip with the access code.
In the APK, you enter the actual mileage in thousands, so 155 represents 155,000 km. Don't be bothered by the fact that the input field shows "0" again; the ash content value will be adjusted accordingly.
Jo_T5
Post28-10-2024, 20:22    Subject: T5 CAAD ash value accidentally set to 0 Quote
Thank you very much, Herbert, for the explanation.
He told me that the ash content would be 0.8g for 80,000 km, which seemed a bit low to me.
Good evening!
4B mit AVF Maschine
No new posts Audi A6 C8, 2020, Oil change interval accidentally reset On-Board Diagnostics (OBD)
No new posts Polo 6R: Engine Byte 4 Not Set - Normal? On-Board Diagnostics (OBD)
No new posts Retrofit DPF (HJS brand), and engine oil with/without add... Diesel Engine Technology
No new posts DPF Ash Reset for BMW 330d with Bavarian Technic On-Board Diagnostics (OBD)
