Coolant loss in CFFB engines after EGR valve replacement
phgraf
Avatar-phgraf
Karma: +14 / -0   Thank you, like it!
Post13-11-2024, 10:42    Subject: Coolant loss in CFFB engines after EGR valve replacement Quote
Good day.
As the title suggests, the engine is losing coolant. Approximately 5mm of condensation formed on the EGR cooler last night.
I've already located the spot, but I'm quite puzzled as to why it's leaking.
It's the hose located at position 16 (see attached image), on the AGR (Exhaust Gas Recirculation) side. There, you can clearly see an outlet.
Yesterday, I tightened the hose again and repositioned the clamp, but there was no improvement. I think I should replace the hose now; maybe I damaged it when I removed it.
The new AGR is a replacement part from Lemförder.
I would appreciate hearing their ideas and suggestions.
Best regards.
 File size:  46.4 KB
 Viewed:  404 times
Translated on 03-07-2026, 22:55.
phgraf
Avatar-phgraf
dieselschrauber likes this.
Post18-11-2024, 14:21    Subject: Coolant loss in CFFB engines after EGR valve replacement Quote
Since then, no further coolant has been lost.
It was probably due to the hose not being assembled quite correctly.
Translated on 03-07-2026, 22:57.
Post18-11-2024, 22:42    Subject: Coolant loss in CFFB engines after EGR valve replacement Quote
Therefore, it was probably due to the hose not being assembled quite correctly.
Thank you for the feedback!
No new posts VW T6 TDI Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Coolant Loss, AGP, AGR, AHF, ALH, AQM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bleed the fuel system of a CFFB engine after filter repla... Diesel Engine Technology
No new posts Warm Start Issues After MSG Swap 1Z to AFN On-Board Diagnostics (OBD)
No new posts A6 AEL: Won't Start After ESP Replacement Diesel Engine Technology
No new posts DPF Replacement: Adjusting Ash Mass On-Board Diagnostics (OBD)
