Throttle learning not possible
phgraf
Avatar-phgraf
Karma: +14 / -0   Thank you, like it!
Post22-01-2025, 11:37    Subject: Throttle learning not possible Quote
I was just about to calibrate the throttle body on a Passat B5 ANA after cleaning it. The conditions were met, but the start button next to the measurement block is grayed out (image).
The search has not yielded any results so far.
Does anyone have any idea what might be causing this?
Best regards.
 File size:  159.28 KB
 Viewed:  1352 times
Post22-01-2025, 19:48    Subject: Throttle learning not possible Quote
Throttle body adaptation (throttle body learning)
phgraf
Avatar-phgraf
dieselschrauber likes this.
Post22-01-2025, 21:06    Subject: Throttle learning not possible Quote
Following this guide, I had already worked, or rather, attempted to work, because things work differently for me.
It's the case that the adaptation starts without any further confirmation, which deviates from the instructions and initially confused me, especially since it happened quite quickly and I didn't notice it at first.
In the video here, I've captured it, hopefully it will be helpful to someone.
Best regards.
Throttle learning not possible - AnpassungBeimVwB5ANA.mp4
 File size:  8.97 MB
 Viewed:  1624 times
Post22-01-2025, 22:04    Subject: Throttle learning not possible Quote
Thank you for your feedback!
No new posts Throttle Body V157 Fault, P3103 Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pairing VW radio keys Troubleshooting & Guides
No new posts Audi Key Fob Pairing: How To Guide Troubleshooting & Guides
No new posts A4 B5 New throttle body cannot be initialized Gasoline Engine Technology
No new posts Audi V8 D11: Diagnosis Not Possible On-Board Diagnostics (OBD)
No new posts Login Error: A4 2.0 TDI - Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Service reset not possible with VCDS RKS 21.3.0.0 On-Board Diagnostics (OBD)
