stolley
28-03-2025, 22:33 Subject: Common rail diesel: Fuel line leak, need to bleed? |
Dear friends,
I now have the opportunity to work on a common-rail diesel engine for the first time.
My daughter's Polo 6R (2015 model year) has a fuel line leak in the engine compartment.
The exchange shouldn't be a problem. I'm just wondering if I need to take any precautions when starting the engine after the repair. Or do I need to somehow bleed the fuel system?
Thank you all!
Translated on 06-07-2026, 10:51.
Herbert Profi-Schrauber
dieselschrauber likes this. |
29-03-2025, 8:20 Subject: Common rail diesel: Fuel line leak, need to bleed? |
Of course, you should bleed it. As with a filter change, run the fuel pump using VCDS. And work cleanly.
Herbert. Horch A4 8K CJCD
Translated on 06-07-2026, 10:52.
stolley
29-03-2025, 8:43 Subject: Common rail diesel: Fuel line leak, need to bleed? |
Great, thanks Herbert!
Volker.
Translated on 06-07-2026, 10:53.
