Turn Signal Lights in Fog Lights
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +2 / -2   Thank you, like it!
Post14-07-2025, 12:44    Subject: Turn Signal Lights in Fog Lights Quote
Good day.
Ich habe einen Golf 7 Bj 2013.Die Nebel-Lampen gehen.Aber das Abbiegelicht ist ohne Funktion. VCDS writes.
Right turn signal, C1084 13 (00001001), interruption.
Who can help? If the right side has a break, why isn't the left side working either?
Sincerely, R. Schelert.
Translated on 18-09-2026, 2:15.
Karma: +805 / -0   Thank you, like it!
Post14-07-2025, 20:40    Subject: Turn Signal Lights in Fog Lights Quote
Obtain a wiring diagram for the vehicle (Erwin). There may be specific cables for the cornering lights leading to the lamps, and make sure that the cornering light function is actually implemented using the fog lights and not the headlights.
Please provide the complete car scan.
Translated on 18-09-2026, 2:16.
dieselschrauber likes this.
Post15-07-2025, 11:05    Subject: Turn Signal Lights in Fog Lights Quote
The Golf 7 comes with various different types of headlights. Sometimes the cornering light is integrated into the fog lights, while in other cases it's a separate light source within the main headlight unit. It seems like your car has the latter type.
Test: Turn on the lights. Activate the left turn signal and turn the steering wheel to the left. Compare the left and right headlights. It's likely that the side that's defective will be the one that's not lit up.
We already had an article about the different types of headlights available for the Golf 7 earlier this year.
Translated on 18-09-2026, 2:17.
Post15-07-2025, 11:08    Subject: Turn Signal Lights in Fog Lights Quote
Huh...?
The last time this topic came up, it was actually brought up by you in May. However, you never responded to it again.
See https://community.dieselschrauber.org/en/viewtopic.php?t=31856&highlight=golf+nebelscheinwerfer.
It would be great if we could receive feedback this time.
Translated on 18-09-2026, 2:18.
dieselschrauber and Bertil likes this.
Post29-07-2025, 8:48    Subject: Golf 7: Turn Signal Problems & Fixes Quote
This Golf doesn't have cornering lights in the fog lights. It only has the cornering light integrated into the headlight.
Due to a faulty bulb, the other side was also shut down.
No new posts High beam on -> Fog lights off? Transmission, Chassis, Body & Interior
No new posts Symmetric Turn Signals: Installation & Wiring Transmission, Chassis, Body & Interior
No new posts A6 4G Cornering Light Coding On-Board Diagnostics (OBD)
No new posts Skoda Octavia 1Z5 RS Cornering Light On-Board Diagnostics (OBD)
